The Redundant Management Interface feature provides fault tolerance for the management path.
To configure Redundant Management, use the following commands.
Redundant Management is supported on the SLX 9250 and the SLX 9740.
  1. Ensure interface management is enabled.
    device# configure
    device(config)# interface management 0
    device(config-Management-0)# ip address dhcp
    device(config-Management-0)# no shut
    device(config-Management-0)# exit
  2. Enable redundant management on an interface/port. RMI is always enabled on one of the physical user ports. To enable RMI on an interface/port:
    device(config)# interface ethernet 0/15
    device(conf-if-eth-0/15)# redundant-management enable
    device(conf-if-eth-0/15)# no shut
    device(conf-if-eth-0/15)# exit
  3. Use show interface management and show interface ethernet commands to verify the configuration.
    (device)# show interface Management 0
    line-speed actual "1000baseT, Duplex: Full"
    oper-status up
    ip address "static 10.24.12.89/22"
    ip gateway-address 10.24.12.1
    ipv6 ipv6-address [  ]
    ipv6 ipv6-gateways [  ]
    redundant management port 0/15
    (device)# show interface ethernet 0/15
    Ethernet 0/15 is admin down, line protocol is down (admin down)
    Redundant management mode is enabled
    Hardware is Ethernet, address is 609c.9f5a.a35f
        Current address is 609c.9f5a.a35f
    Pluggable media not present
    Description: Insight port
    Interface index (ifindex) is 202350592 (0xc0fa000)
    MTU 9216  bytes
    Maximum Speed        : 10G
    LineSpeed Actual     : Nil
    LineSpeed Configured : Auto, Duplex: Full
    Priority Tag disable
    Forward LACP PDU: Disable
    Route Only: Disabled
    Tag-type: 0x8100
    Last clearing of show interface counters: 00:01:13
    Queueing strategy: fifo
    FEC Mode - Disabled
    Receive Statistics:    0 packets, 0 bytes
        Unicasts: 0, Multicasts: 0, Broadcasts: 0
        64-byte pkts: 0, Over 64-byte pkts: 0, Over 127-byte pkts: 0
        Over 255-byte pkts: 0, Over 511-byte pkts: 0, Over 1023-byte pkts: 0
        Over 1518-byte pkts(Jumbo): 0
        Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0
        Errors: 0, Discards: 0
    Transmit Statistics:
        0 packets, 0 bytes
        Underruns: 0    Errors: 0, Discards: 0
    Rate info:
        Input 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
        Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
    Route-Only Packets Dropped: 0
    Time since last interface status change: 00:01:13
