Feature support for SSH
SSHv2 is the supported version of SSH, but not all features typically available with SSHv2 are supported on the Extreme devices.
The following encryption algorithms are
supported:
3des-cbc Triple-DES
aes256-cbc: AES in Cipher Block Chaining (CBC) mode with 256-bit key
aes192-cbc: AES in CBC mode with 192-bit key
aes128-cbc: AES in CBC mode with 128-bit key
aes256-gcm: AES in Galios/Counter Mode (GCM) mode with 256-bit key
- aes256-gcm@openssh.com
aes192-gcm: AES in GCM mode with 192-bit key
aes128-gcm: AES in GCM mode with 128-bit key
- aes128-gcm@openssh.com
aes256-ctr: AES in Counter Mode (CTR) mode with 256-bit key
aes192-ctr: AES in CTR mode with 192-bit key
aes128-ctr: AES in CTR mode with 128-bit key
- blowfish-cbc
- cast128-cbc
- arcfour
- arcfour128
- arcfour256
- rijndael-cbc@lysator.liu.se
- chacha20-poly1305@openssh.com
The following Hash-based Message Authentication Code (HMAC) message authentication algorithms are supported:
hmac-md5: MD5 encryption algorithm with 128-bit key.
- hmac-md5-96
hmac-sha1: SHA1 encryption algorithm with 160-bit key.
- hmac-sha1-96
hmac-sha2-256: SHA2 encryption algorithm with 256-bit key.
- hmac-sha2-256-etm@openssh.com
hmac-sha2-512: SHA2 encryption algorithm with 512-bit key.
- hmac-sha2-512-etm@openssh.com
- hmac-ripemd160
- hmac-ripemd160@openssh.com
- umac-64@openssh.com
- umac-128@openssh.com
- hmac-sha1-etm@openssh.com
- hmac-sha1-96-etm@openssh.com
- hmac-md5-etm@openssh.com
- hmac-ripemd160-etm@openssh.com
- umac-64-etm@openssh.com
- umac-128-etm@openssh.com
The following host keys are supported:
The following key exchange algorithms are
supported:
- diffie-hellman-group-exchange-sha256
- diffie-hellman-group-exchange-sha1
- diffie-hellman-group18-sha512
- diffie-hellman-group16-sha512
- diffie-hellman-group14-sha256
- diffie-hellman-group14-sha1
- diffie-hellman-group1-sha1
- curve25519-sha256
- curve25519-sha256@libssh.org
- ecdh-sha2-nistp256
- ecdh-sha2-nistp384
- ecdh-sha2-nistp521
SSH user authentication is performed with passwords stored on the device or on an external authentication, authorization, and accounting (AAA) server.
