To display the global LLDP status, use the show lldp command.
device# show lldp LLDP Global Information system-name: SLX system-description: Extreme BR-SLX9540-4 Router description: Extreme-LLDP State: Enabled Mode: Receive/Transmit Advertise Transmitted: 30 seconds Hold time for advertise: 120 seconds Tx Delay Timer: 1 seconds Transmit TLVs: Chassis ID Port ID TTL Port Description System Name
To display LLDP status for an Ethernet interface, use the show lldp interface ethernet command.
device# show lldp interface ethernet 0/18 LLDP information for Eth 0/18 State: Enabled Mode: Receive/Transmit Advertise Transmitted: 30 seconds Hold time for advertise: 120 seconds Tx Delay Timer: 1 seconds Transmit TLVs: Chassis ID Port ID TTL Port Description System Name
To display the LLDP neighbor information, use the show lldp neighbors command. This command allows you to display the information for all Ethernet interfaces, a specific interface, or detailed neighbor information.
The following example displays the LLDP neighbor information for all interfaces.
device# show lldp neighbors Local Port Dead Interval Remaining Life Remote Port ID Remote Port Descr Chassis ID Tx Rx System Name Eth 0/18 120 102 Ethernet 0/25 Eth 2/25 768e.f807.6000 653 652 R6 Eth 0/21 120 108 Ethernet 0/21 Eth 1/21 768e.f807.6000 653 652 R6 Eth 0/40 120 110 Ethernet 0/50 Eth 1/50 768e.f807.6000 653 650 R6 Eth 0/43 120 102 Ethernet 0/51 Eth 2/51 768e.f807.6000 653 652 R6 Eth 0/50 120 102 Ethernet 0/23 Eth 2/23 768e.f807.6000 653 611 R6
The following example displays the LLDP neighbor information for Ethernet interface 0/18.
device# show lldp neighbors interface ethernet 0/18 Local Port Dead Interval Remaining Life Remote Port ID Remote Port Descr Chassis ID Tx Rx System Name Eth 0/18 120 115 Ethernet 0/25 Eth 0/25 768e.f807.6000 655 654 R6
The following example displays the detailed LLDP neighbor information for Ethernet interface 1/18.
device# show lldp neighbors interface ethernet 0/18 detail Neighbors for Interface Eth 0/18 MANDATORY TLVs =============== Local Interface: Eth 0/18 (Local Interface MAC: 768e.f805.5816) Remote Interface: Ethernet 0/25 (Remote Interface MAC: 768e.f807.610d) Dead Interval: 120 secs Remaining Life : 118 secs Chassis ID: 768e.f807.6000 LLDP PDU Transmitted: 656 Received: 655 OPTIONAL TLVs ============== Port Interface Description: Eth 0/25 System Name: R6
To display the LLDP statistics for all interfaces or a specific interface, use the show lldp statistics command.
The following example displays the statistics for Ethernet interface 0/18.
device# show lldp statistics interface ethernet 0/18 LLDP Interface statistics for Eth 0/18 Frames transmitted: 659 Frames Aged out: 0 Frames Discarded: 0 Frames with Error: 0 Frames Recieved: 657 TLVs discarded: 0 TLVs unrecognized: 0
If you do not include the interface ethernet option, the command displays the statistics for all interfaces.
