This restoration procedure resets the configuration to the factory defaults. The default configuration files are always present on the device and can be restored with the copy command.
To restore the default configuration, perform the following procedure in privileged EXEC mode.
device# copy default-config startup-config
This operation will modify your startup configuration. Do you want to continue? [Y/N]: y
device# reload system
