The Insight Interface is configured on both the SLX endpoint and the TPVM endpoint. Use the following procedure to configure the SLX endpoint of the Insight Interface. Note that steps 1 through 4 are specific to the SLX 9540 and SLX 9640.
  1. Enter global configuration mode.
    device# configure terminal
  2. Enter the hardware command to enter hardware configuration mode. (This is required for the SLX 9540/9640 only.)
    device(config)# hardware
  3. Enter the connector command to specify a slot and port.
    device(config-hardware)# connector 0/48
  4. Enter the insight mode command to enable the insight interface on a port-channel, and exit to global configuration mode.
    device(connector-0/48)# insight mode
For the SLX 9640 use Eth 0/24. The command will toggle the physical port, and will display as port 0/125 in any show commands.
  1. Exit to global configuration mode.
    device(connector-0/48)# exit
  2. In global configuration mode, specify a port-channel. You can create a new port-channel or use an existing unconfigured port-channel. The Insight Interface can only be configured on one port-channel
    device(config)# interface port-channel 22
  3. In interface subtype configuration mode, enter the insight enable command.
    device(config-Port-channel-22)# insight enable
  4. Set the port ip-address.
    device(config-Port-channel-20)# ip address 10.0.0.1/24
  5. Enable the interface.
    device(config-Port-channel-22)# no shutdown
  6. Use the show interface port-channel and the show port-channel commands to confirm the configuration, as in the following example.
    device# show interface port-channel 22
    Port-channel 22 is up, line protocol is up
    Hardware is AGGREGATE, address is 609c.9f5a.4558
        Current address is 609c.9f5a.4558
    Interface index (ifindex) is 671088673
    Minimum number of links to bring Port-channel up is 1
    MTU 1548 bytes
    LineSpeed Actual     : 10000 Mbit
    Allowed Member Speed : 10000 Mbit
    Priority Tag disable
    Forward LACP PDU: Disable
    Route Only: Disabled
    Last clearing of show interface counters: 1d23h53m
    Queueing strategy: fifo
    Receive Statistics:
        0 packets, 0 bytes
        Unicasts: 0, Multicasts: 0, Broadcasts: 0
        64-byte pkts: 0, Over 64-byte pkts: 0, Over 127-byte pkts: 0
        Over 255-byte pkts: 0, Over 511-byte pkts: 0, Over 1023-byte pkts: 0
        Over 1518-byte pkts(Jumbo): 0
        Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0
        Errors: 0, Discards: 0
    Transmit Statistics:
        5 packets, 380 bytes
        Unicasts: 0, Multicasts: 5, Broadcasts: 0
        Underruns: 0
    Rate info:
        Input 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
        Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate
    Route-Only Packets Dropped: 0
    Time since last interface status change: 00:00:21
    device# show port-channel 22
    Static Aggregator: Po 22
     Aggregator type: Standard
     Number of Ports: 1
     Member ports:
       Eth 0/125   *
