New CLI to download new TPVM image to /tftpboot/SWBD2900 folder. If SLX had any previously deployed TPVM as per new mode introduced in this release SLX-OS 20.3.2, then that will be stop/uninstalled and new image shall be deployed and previously set TPVM configurations will be applied too.
Example 1) This example describes how to upgrade TPVM. The TPVM may or may not be running. The internal workflow is as follows:
(SLX-OS configuration is not impacted).SLX# tpvm upgrade protocol scp host 10.31.2.101 directory /folder/to/debian
filename tpvm-4.2.5-1.amd64.deb user mylogin password mypasswd
The deploy command is a time-taking operation. If executed through the Netconf/RPC, it is non-blocking to the client and will proceed in the background at the SLX switch. The Raslog “DCMD-1451” (for start), “DCMD-1452” (for success) and “DCMD-1453” (for fail/abort) are published.
