Python scripts enable you to manipulate and launch Extreme operating system commands, taking advantage of the power and flexibility of Python. Such scripts also support event handling.
The topics in this section guide you through the process of writing and testing Python scripts, copying them to supported devices, and running them with the python command from the command line.
