SNMPv3 uses SNMP users to restrict SNMP access. When you map an SNMP user to an SNMP group, you can restrict the access of MIBs for SNMP requests through an SNMP view.
device# configure terminal
device(config)# snmp-server contact "Network Management group - Contact # 123-123-1234"
The double quotes allows you to enter the string with spaces.
device(config)# snmp-server location "South Room, Rack-11"
device(config)# snmp-server view view2 1.3.6.1 included
device(config)# snmp-server group group1 v3 priv write view2 notify view2
device(config)# snmp-server user user2 groupname group1 auth md5 auth-password private123 priv DES priv-password public123
This example adds the user2 user and associates it with the group1 group to access of MIBs for SNMPv3 requests. For SNMPv3 users, the passwords for auth-password and priv-password keywords are encrypted while storing to the persistent memory or displaying it back to the user. You can configure either with a plain-text password or an encrypted password. In both cases, the show running-config command displays the passwords as encrypted.
device(config)# snmp-server v3host 10.26.3.166 user2 severity-level Info udp-port 4425
This example configures 10.26.3.166 as an SNMPv3 trap recipient host on the target port 4425 and associates the user2 user.
The global SNMPv3 host can be associated with global SNMPv3 users only. You cannot create an SNMPv3 host in a global configuration by associating it with local SNMPv3 users.
device(config)# snmp-server enable trap
device(config)# exit
device# show running-config snmp-server snmp-server contact "Network Management group - Contact # 123-123-1234" snmp-server enable trap snmp-server location "South Room, Rack-11" snmp-server group group1 v3 priv write view2 notify view2 snmp-server user user2 groupname group1 md5 auth-password private123 priv DES priv-password public123 snmp-server v3host 10.26.3.166 user2 severity-level Info udp-port 4425 ! snmp-server view view2 1.3.6.1 included
The following example shows the previous steps to configure SNMPv3.
device# configure terminal device(config)# snmp-server contact "Network Management group - Contact # 123-123-1234" device(config)# snmp-server location "South Room, Rack-11" device(config)# snmp-server view view2 1.3.6.1 included device(config)# snmp-server group group1 v3 priv write view2 notify view2 device(config)# snmp-server user user2 groupname group1 md5 auth-password private123 priv DES priv-password public123 device(config)# snmp-server v3host 10.26.3.166 user2 severity-level Info udp-port 4425 device(config)# snmp-server enable trap
