With admin-level permissions, you can access the SLXVM Linux shell from the SLX-OS CLI, by using the start-shell command.
Inside the SLXVM Linux shell, you can execute commands that do not require root permissions. To escalate your permissions, refer to "Escalating Linux permissions to root".device# start-shell Entering Linux shell for the user: admUser [admUser@SLX]#
[admUser@SLX]# exit
exit Exited from Linux shell device#
