The following examples illustrate how to display the default, startup, and running configurations, respectively.
To display the default configuration, enter the show file command with the default configuration filenames in privileged EXEC mode.
device# show file defaultconfig.standalone device# show file defaultconfig.cluster
To display the contents of the startup configuration, enter the show startup-config command in privileged EXEC mode.
device# show startup-config
To display the contents of the running configuration, enter the show running-config command in the privileged EXEC mode.
device# show running-config
