This section addresses details of the insight interface port on different Extreme SLX platforms.
Extreme SLX 9540
- Either front-port 0/48 or the insight interface port 0/125 can exist at a given time, as these ports share the same ASIC port.
- By default, 0/48 is created.
- Insight mode can be configured by means of the
connector 0/48 command. A port-channel cannot be made an insight port-channel until insight interface mode is enabled on connector 0/48. Similarly, insight mode cannot be removed on connector 0/48 until the connector is unbound from the insight port-channel.
- Upon insight mode configuration, interface 0/48 is dynamically deleted and 0/125 is created.
- All the configurations under interface 0/48 are deleted upon insight mode configuration.
- An existing port-channel with existing member ports
cannot be made an insight interface port-channel.
The following is an example configuration.
device(config)# hardware
device(config-hardware)#
device(config-hardware)# connector 0/48
device(config-connector-0/48)# [no] insight mode
device(config)# interface port-channel 20
device(config-Port-channel-20)# insight enable
Extreme SLX 9640
- Either front-port 0/24 or the insight interface port 0/126 can exist at a given
- By default, 0/24 is created.
- Insight mode can be configured by means of the connector 0/24
interface mode is enabled on connector 0/24. Similarly, insight mode cannot be
removed on connector 0/24 until the connector is unbound from the insight
port-channel.
- Upon insight mode configuration, interface 0/24 is dynamically deleted and 0/126
is created.
- All the configurations under interface 0/24 are deleted upon insight mode
configuration.
- An existing port-channel with existing member ports cannot be made an insight
