QoS rate shaping
QoS rate shaping allows you to limit egress traffic to a specified rate.
Rate shaping works under the following rules and limitations:
- If there is a higher data rate than the configured shaping rate, traffic is kept at the ingress VOQ.
- The ingress TM tail drops packets if the queue is full.
- Accuracy is +- 3%.
- Configuration granularity is 1KB.
