The SLX 9150 and SLX 9250 use directly connected, dedicated internal ethernet ports for TPVM access. These ports are used exclusively for VM access and are not accessible from the command line interface. Use the following steps to configure a port channel to access the Insight Interface on the SLX 9150 and SLX 9250.
device# configure terminal
device(config)# interface port-channel 50
device(config-Port-channel-50)# insight enable
device(config-Port-channel-50)# ip address 10.0.0.1/24
device(config-Port-channel-50)# no shutdown
device# show interface port-channel 50 Port-channel 50 is up, line protocol is up Insight mode is enabled Hardware is AGGREGATE, address is f46e.959f.1af5 Current address is f46e.959f.1af5 Interface index (ifindex) is 671088690 (0x28000032) Minimum number of links to bring Port-channel up is 1 MTU 9216 bytes LineSpeed Actual : 10000 Mbit Allowed Member Speed : 10000 Mbit Priority Tag disable Forward LACP PDU: Disable Route Only: Disabled Tag-type: 0x8100 Last clearing of show interface counters: 4d18h22m Queueing strategy: fifo FEC Mode - Disabled Receive Statistics: 0 packets, 0 bytes Unicasts: 0, Multicasts: 0, Broadcasts: 0 64-byte pkts: 0, Over 64-byte pkts: 0, Over 127-byte pkts: 0 Over 255-byte pkts: 0, Over 511-byte pkts: 0, Over 1023-byte pkts: 0 Over 1518-byte pkts(Jumbo): 0 Runts: 0, Jabbers: 0, CRC: 0, Overruns: 0 Errors: 0, Discards: 0 Transmit Statistics: 12 packets, 5589 bytes Unicasts: 0, Multicasts: 12, Broadcasts: 0 Underruns: 0 Errors: 0, Discards: 0 Rate info: Input 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate Output 0.000000 Mbits/sec, 0 packets/sec, 0.00% of line-rate Route-Only Packets Dropped: 0 Time since last interface status change: 00:00:25
