Configure Remote Attestation
For Remote Attestation to work, Measured Boot must be enabled. To learn more about Measured Boot, see Measured Boot in this document.
Remote Attestation is supported on Extreme 8720 and Extreme 8520 devices.
To configure Remote Attestation do the following:
  1. Navigate into the configuration mode
    SLX # configure terminal
    SLX (config)#
  2. Enable Measured Boot.
    SLX (config)# measure-boot enable
    SLX (config)#
  3. Enter the Remote Attestation configuration mode.
    SLX (config)# remote-attestation
    SLX (config-remote-attestation)#
  4. Configure the remote Remote Attestation server first. Here you will configure the settings for the VRF that will be used to access the Remote Attestation server.
    SLX (config-remote-attestation)# registrar-server 10.1.1.1 use-vrf default-vrf
    SLX (config-remote-attestation-10.1.1.1/default-vrf)#
  5. Configure the port on which the Remote Attestation server is listening. This configuration is done on the VRF configured in the previous step.
    SLX (config-remote-attestation-10.1.1.1/default-vrf)# registrar-port
    The default port is 8890. If your Remote Attestation server is listening on another port, enter that port number here. Valid values are in the range 0-65535.
  6. Exit out of registrar-server configuration mode.
    SLX (config-remote-attestation-10.1.1.1/default-vrf)# exit
    SLX (config-remote-attestation) #
  7. Configure the Remote Attestation Agent UUID.
    SLX(config-remote-attestation)# agent-uuid ?
    Possible completions:
    	<1-100>   UUID of the device.[auto]
    The show remote-attestation status displays UUID status.
  8. Configure the Remote Attestation listening port.
    SLX(config-remote-attestation)# agent-port ?
      <Choose the port number in the range 0 - 65535>
    The Remote Attestation agent is configured to listen on port 9002 by default. If your Remote Attestation agent is listening on a different port, configure that port here. Port can be in the range 0-65535.
  9. Enable the Remote Attestation agent.
     SLX (config-remote-attestation) # agent-enable
  10. Exit out of the Remote Attestation configuration mode.
    SLX (config-remote-attestation) # exit
    SLX (config)#
  11. Exit out of the Global Configuration mode.
    SLX (config)# exit
    SLX #
