NTP works in one or more association modes.
The Server mode requires no prior client configuration; it responds to Client mode NTP packets. The ntp server enable command is used to set the device to operate in Server mode. Use no ntp disable serve to ensure NTP is configured in server mode.
When the system is operating in Client mode, all configured NTP servers and peers are polled. The device selects a host from all the polled NTP Servers from which to synchronize. To configure the NTP servers and peers individually, use the server and peer commands.
NTP Peer mode is intended for configurations where a group of devices operate as mutual backup for one another. If one device loses a reference source, the time values flow from the remaining peers.
The NTP peer can operate in:
