To investigate the contents of a file in the flash memory, enter the show file command with the file name in privileged EXEC mode.
device# show file defaultconfig.cluster vlan dot1q tag native ! cee-map default remap fabric-priority priority 0 remap lossless-priority priority 0 priority-group-table 15.0 pfc off priority-group-table 1 weight 40 pfc on priority-group-table 2 weight 60 pfc off priority-table 2 2 2 1 2 2 2 15.0 ! ! port-profile default vlan-profile switchport switchport mode trunk switchport trunk allowed vlan all ! protocol lldp ! ! logging auditlog class CONFIGURATION logging auditlog class FIRMWARE logging auditlog class SECURITY ! end
To display the contents of the running configuration, use the show running-config command. To display the contents of the startup configuration, use the show startup-config command.
