Describes the settings for enabling heartbeat message monitoring by SLX devices.
Heartbeat monitoring is configured from a sub-context under Global Configuration.
management-heartbeat manager
command.
The context changes to SLX(config-management-heartbeat-manage) #
prompt.
SLX(config) # management-heartbeat manager SLX(config-management-heartbeat-manage) #
threshold-value <threshold-value-in-minutes>
command to configure this
value.
[no] threshold-value
command to reset the threshold timer value.
This is the time duration for which the SLX device listens for a heartbeat message from EFA and on expiry of this threshold time, the device goes into a Management Operational State - Down state.
This example sets the threshold value to thirty (30) minutes. The default value for this command is five (5) minutes.
SLX(config-management-heartbeat-manage) # threshold-value 30
When the no threshold-value
command is used, the threshold is
reverted to the default value of 5 minutes.
SLX(config-management-heartbeat-manage) # no threshold-value
action
command to do so.
action
command can set the SLX device into management mode only. If
no action is needed, the use the no-action
command.
When the SLX device does not receive any heartbeat message from the EFA, then it can either enter into Management Operational State - Down or perform no action.
The following example is for configuring an action of setting the SLX device to Management Operational State - Down.
SLX(config-management-heartbeat-manage) # action maintenance-mode-enable
The following example is for taking no action.
SLX(config-management-heartbeat-manage) # action no-action
show management-heartbeat-manager
command.
SLX(config-management-heartbeat-manage) # show management-heartbeat-manager Admin state: down Operational state: up Threshold time: 30 minutes Action: Maintenance mode enable Time to last heartbeat: 4 minutes SLX(config-management-heartbeat-manage) #
enable
command to enable Heartbeat monitoring on the SLX device.
SLX(config-management-heartbeat-manage) # enable SLX(config-management-heartbeat-manage) # show management-heartbeat-manager Admin state: up Operational state: up Threshold time: 30 minutes Action: Maintenance mode enable Time to last heartbeat: 30 minutes
