Telnet, HTTP, and SSH limitations and
considerations
considerations are as follows:
- By default, SSH and Telnet services
are associated and started on mgmt-vrf and default-vrf.
- You cannot remove mgmt-vrf from the SSH
and Telnet services.
- Telnet and SSH server can be enabled on a maximum
number of 32 VRFs.
- SSH and Telnet Services started on VRF
context is applicable for both IPv4 and IPv6 addresses.
- A maximum of 32 user logins are allowed
in the device. These sessions are a cumulative count of login sessions through
SSH and Telnet across all the configured VRFs.
- Inter-VRF route leaking is not supported for
SSH, HTTP, HTTPS, and Telnet. When you try to use any of these services to
access a leaked VRF (user-vrf), the connection is refused. In addition, the
access service ceases to function correctly on the local VRF (mgmt-vrf) and you
must restart it; for example, to restart the SSH service on the local VRF, run
the ssh server restart
command.
