Use this topic to copy a file from a USB stick to an Extreme device.
Important
The only supported USB device for this task is the Extreme USB stick shipped with the device.device# copy usb://pythscript1.py flash://pythscript1.py
device# dir total 32 drwxr-xr-x 2 251 1011 4096 Aug 26 08:44 . drwxr-xr-x 3 251 1011 4096 Jul 20 07:50 .. -rw-r--r-- 1 root root 1051 Mar 24 16:09 create_po.py -rw-r--r-- 1 root sys 695 Aug 23 21:18 defaultconfig.cluster -rw-r--r-- 1 root root 410 Aug 26 04:06 defaultconfig.standalone -rw-r--r-- 1 root root 10042 Aug 4 00:01 ospfnsr1.cfg -rw-r--r-- 1 root root 410 Aug 26 01:28 startup-config 16908197888 bytes total (10226114560 bytes free)
device# show file pythscript1.py
