Configures a tunnel.
| URI | Description |
| <base_URI>/config/running/interface/tunnel | Configures a tunnel. |
| GET URIs | Description |
| <base_URI>/config/running/interface/tunnel/{identifier}/mode | Retrieves tunnel encapsulation method. |
| <base_URI>/config/running/interface/tunnel/{identifier}/source | Retrieves source of tunnel. |
| <base_URI>/config/running/interface/tunnel/{identifier}/destination | Retrieves destination IP address. |
| <base_URI>/config/running/interface/tunnel/{identifier}/ttl | Retrieves tunnel TTL. |
| <base_URI>/config/running/interface/tunnel/{identifier}/dscp | Retrieves tunnel DSCP. |
| <base_URI>/config/running/interface/tunnel/{identifier}/name | Retrieves tunnel name. |
| <base_URI>/config/running/interface/tunnel/{identifier}/dscp-ttl-mode | Retrieves tunnel DSCP TTL mode. |
| <base_URI>/config/running/interface/tunnel/{identifier}/statistics | Retrieves tunnel statistics. |
| <base_URI>/config/running/interface/tunnel/{identifier}/keepalive | Retrieves tunnel keepalive. |
| <base_URI>/config/running/interface/tunnel/{identifier}/keepalive/retry-count | Retrieves retry count. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/interface | <tunnel><identifier>{uint32}</identifier></tunnel> | Creates a tunnel. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/interface/tunnel/{identifier}/mode/gre/ip | <ip>{enumeration}</ip> | Enables generic routing encapsulation (GRE) over a tunnel interface and specifies that the tunneling protocol is IPv4. |
| <base_URI>/config/running/tunnel/{identifier}/source/source-address | <source-address>{inet:ipv4-address}</source-address> | Configures the source IP address. |
| <base_URI>/config/running/interface/tunnel/{identifier}/destination | <destination>{inet:ipv4-address}</destination> | Configures the destination IP address. |
| <base_URI>/config/running/interface/tunnel/{identifier}/router-interface/ve | <ve>{uint32}</ve> | Configures the router interface for a tunnel. |
| <base_URI>/config/running/interface/tunnel/{identifier}/ttl | <ttl>{uint32}</ttl> | Configures Tunnel TTL. |
| <base_URI>/config/running/interface/tunnel/{identifier}/dscp | <dscp>{uint32}</dscp> | Configures Tunnel DSCP. |
| <base_URI>/config/running/interface/tunnel/{identifier}/statistics | <statistics>{enumeration}</statistics> | Configures Tunnel statistics. |
| <base_URI>/config/running/interface/tunnel/{identifier}/keepalive | <keepalive><time-interval>{uint32}</time-interval><retry-count>{uint32}</retry-count></keepalive> | Configures Tunnel keepalive. |
| DELETE URIs |
| <base_URI>/config/running/interface/tunnel/{identifier} |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/tunnel/1/mode
None
<mode xmlns="urn:brocade.com:mgmt:brocade-gre-vxlan" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/interface/tunnel/1/mode">
<gre y:self="/rest/config/running/interface/tunnel/1/mode/gre">
<ip>true</ip>
</gre>
</mode>
The following is an example of the PUT operation to configure GRE over a tunnel interface and specifies that the tunneling protocol is IPv4..
http://host:80/rest/config/running/interface/tunnel/1/mode/gre/ip
<ip>true</ip>
None
The following is an example of the DELETE operation to remove a tunnel.
None
None
