Configures, modifies, or retrieves Transient Buffer Congestion Detection settings.
| GET URIs | Description |
| <base_URI>/config/running/system-monitor/tm/discard-packet/threshold | Traffic Manager discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/discard-packet/logging-interval | Traffic Manager discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/discard-voq-packet/threshold | Traffic Manager VOQ discarded packets |
| <base_URI>/config/running/system-monitor/tm/discard-voq-packet/logging-interval | Traffic Manager VOQ discarded packets |
| <base_URI>/config/running/system-monitor/tm/delete-packet/threshold | Traffic Manager VOQ deleted packet monitoring |
| <base_URI>/config/running/system-monitor/tm/delete-packet/logging-interval | Traffic Manager VOQ deleted packet monitoring |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/system-monitor/tm/discard-packet/threshold | <threshold>{uint32}</threshold> | Sets threshold for Traffic Manager discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/discard-packet/logging-interval | <logging-interval>{uint16}</logging-interval> | Sets logging interval for Traffic Manager discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/discard-voq-packet/threshold | <threshold>{uint32}</threshold> | Sets threshold for Traffic Manager VOQ discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/discard-voq-packet/logging-interval | <logging-interval>{uint16}</logging-interval> | Sets logging interval for Traffic Manager VOQ discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/delete-packet/threshold | <threshold>{uint32}</threshold> | Sets threshold for Traffic Manager deleted packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/delete-packet/logging-interval | <logging-interval>{uint16}</logging-interval> | Sets logging interval for Traffic Manager deleted packet monitoring. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/system-monitor/tm/discard-packet | <discard-packet><threshold>{uint32}</threshold></discard-packet> | Sets threshold for Traffic Manager discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/discard-packet | <discard-packet><logging-interval>{uint16}</logging-interval></discard-packet> | Sets logging interval for Traffic Manager discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/discard-voq-packet | <discard-voq-packet><threshold>{uint32}</threshold></discard-voq-packet> | Sets threshold for Traffic Manager VOQ discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/discard-voq-packet | <discard-voq-packet><logging-interval>{uint16}</logging-interval></discard-voq-packet> | Sets logging interval for Traffic Manager VOQ discard packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/delete-packet | <delete-packet><threshold>{uint32}</threshold></delete-packet> | Sets threshold for Traffic Manager deleted packet monitoring. |
| <base_URI>/config/running/system-monitor/tm/delete-packet | <delete-packet><logging-interval>{uint16}</logging-interval></delete-packet> | Sets logging interval for Traffic Manager deleted packet monitoring. |
| DELETE URIs |
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/system-monitor/tm/discard-packet/threshold
None
<threshold xmlns="urn:brocade.com:mgmt:brocade-system-monitor" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/system-monitor/tm/discard-packet/threshold">14</threshold>
The following example uses the PUT option .
<threshold>14</threshold>
None
The following example uses the DELETE option .
None
None
