Configures, retrieves, and modifies Link Fault Signaling (LFS).
| URI | Description |
| <base_URI>/config/running/link-fault-signaling | Configures LFS |
| GET URIs | Description |
| <base_URI>/config/running/link-fault-signaling | Retrieves LFS |
| <base_URI>/config/running/link-fault-signaling/tx | Retrieves TX LFS |
| <base_URI>/config/running/link-fault-signaling/rx | Retrieves RX LFS |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/link-fault-signaling/rx | <rx>(enumeration)</rx> | Configures RX LFS |
| <base_URI>/config/running/link-fault-signaling/tx | <tx>(enumeration)</tx> | Configures TX LFS |
| PUT URIs | Payload | Description |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/link-fault-signaling
None
<link-fault-signaling xmlns="urn:brocade.com:mgmt:brocade-lfs" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/link-fault-signaling"> <rx>on</rx> <tx>on</tx> </link-fault-signaling>
The following example uses the PATCH option to configure RX LFS.
http://host:80/rest/config/running/link-fault-signaling/rx
<rx>on</rx>
None
The following example uses the DELETE option to remove TX LFS.
http://host:80/rest/config/running/link-fault-signaling/tx
None
None
