Configures, retrieves, and modifies AAA login sequence.
| URI | Description |
| <base_URI>/config/running/aaa/authentication | Configures AAA login sequence. |
| GET URIs | Description |
| <base_URI>/config/running/aaa/authentication/login | Specifies the type of server that will be used for authentication, authorization, and accounting (AAA) on the device. The local server is the default. |
| <base_URI>/config/running/aaa/authentication/login/first | Configures the primary source of authentication. |
| <base_URI>/config/running/aaa/authentication/login/second | Configures the secondary source of authentication. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/aaa/authentication/login | <login><first>{enumeration}</first></login> | Configures the order of sources for login and sets the primary source of authentication. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/aaa/authentication/login/first | <first>{enumeration}</first> | Configures the order of sources for login and sets the primary source of authentication. |
| <base_URI>/config/running/aaa/authentication/login/second | <second>{enumeration}</second> | Configures the order of sources for login and sets the secondary source of authentication. |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/aaa/authentication
None
<authentication xmlns="urn:brocade.com:mgmt:brocade-aaa"
xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/aaa/authentication">
<login y:self="/rest/config/running/aaa/authentication/login">
<first>radius</first>
<second>local-auth-fallback</second>
</login>
</authentication>
The following example uses the PUT option to configure AAA login sequence.
http://host:80/rest/config/running/aaa/authentication/login/first
None
The following example uses the DELETE option to remove AAA login sequence.
None
None
