Configures, retrieves, and modifies RSTP.
| URI | Description |
| <base_URI>/config/running/protocol/spanning-tree/rstp | Configures RSTP. |
| GET URIs | Description |
| <base_URI>/config/running/protocol/spanning-tree/rstp | Retrieves RSTP. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/error-disable-timeout | Retrieves error disable timeout. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/port-channel | Retrieves RSTP on port channel. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/protocol/spanning-tree | <rstp></rstp> | Configures RSTP. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/error-disable-timeout | <enable></enable> | Enables RSTP error disable. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/port-channel | <shutdown></shutdown> | Shuts down. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/protocol/spanning-tree/rstp/description | <description>(string)</description> | Configures RSTP description. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/bridge-priority | <bridge-priority>(unit32)</bridge-priority> | Configures RSTP bridge priority. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/error-disable-timeout/enable | <enable></enable> | Enables error disable timeout. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/error-disable-timeout/interval | <interval>(unit32)</interval> | Configures error disable timeout interval. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/forward-delay | <forward-delay>(unit32)</forward-delay> | Configures forward delay. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/max-age | <max-age>(unit32)</max-age> | Configures max age. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/port-channel/path-cost | <path-cost>(string)</path-cost> | Configures path cost. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/shutdown | <shutdown></shutdown> | Shuts down. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/hello-time | <hello-time>(unit32)</hello-time> | Configures hello time. |
| <base_URI>/config/running/protocol/spanning-tree/rstp/transmit-holdcount | <transmit-holdcount>(unit32)</transmit-holdcount> | Configures transmit hold count. |
| PUT URIs | Payload | Description |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/protocol/spanning-tree
None
<spanning-tree xmlns="urn:brocade.com:mgmt:brocade-xstp" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/protocol/spanning-tree">
<rstp y:self="/rest/config/running/protocol/spanning-tree/rstp">
<error-disable-timeout y:self="/rest/config/running/protocol/spanning-tree/rstp/error-disable-timeout">
</error-disable-timeout>
<port-channel y:self="/rest/config/running/protocol/spanning-tree/rstp/port-channel">
</port-channel>
</rstp>
</spanning-tree>
The following example uses the POST option to configure RSTP.
<rstp></rstp>
None
The following example uses the DELETE option to remove RSTP description.
http://host:80/rest/config/running/protocol/spanning-tree/rstp/description
None
None
