Configures, modifies, or retrieves Remote Monitoring Protocol (RMON) information.
| URI | Description |
| <base_URI>/config/running/rmon | Remote Monitoring Protocol (RMON). |
| GET URIs | Description |
| <base_URI>/config/running/rmon/event/{event-index}/description | Retrieves event description. |
| <base_URI>/config/running/rmon/event/{event-index}/log | Retrieves logged events. |
| <base_URI>/config/running/rmon/event/{event-index}/trap | Retrieves event trap information. |
| <base_URI>/config/running/rmon/event/{event-index}/owner | Retrieves event owner identity. |
| <base_URI>/config/running/rmon/alarm/{alarm-index}/event | Retrieves event for falling alarm. |
| <base_URI>/config/running/rmon/alarm/{alarm-index}/owner | Retrieves alarm owner identity. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/rmon | <event><event-index>(int32)</event-index></event> | Configures RMON event. |
| <base_URI>/config/running/rmon | <alarm><alarm-index>(int32)</alarm-index><snmp-oid>(string)</snmp-oid><interval>(int32)</interval><type>(string)</type><rising-threshold>(unit32)</rising-threshold><event>(int32)</event></alarm> | Configures RMON alarm. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/rmon/event/{event-index} | <event><description>(string)</description></event> | Configures RMON event description. |
| <base_URI>/config/running/rmon/event/{event-index} | <event><log>(string)</log></event> | Configures event log. |
| <base_URI>/config/running/rmon/event/{event-index} | <event><trap>(string)</trap></event> | Configures event trap. |
| <base_URI>/config/running/rmon/event/{event-index} | <event><owner>(string)</owner></event> | Configures event owner. |
| <base_URI>/config/running/rmon/alarm/{alarm-index} | <alarm><snmp-oid>(string)</snmp-oid><interval>(int32)</interval><type>(string)</type><rising-threshold>(unit32)</rising-threshold><event>(int32)</event></alarm> | Configures RMON alarm. |
| <base_URI>/config/running/rmon/alarm/{alarm-index} | <alarm><falling-threshold>(uint32)</falling-threshold><event>(int32)</event></alarm> | Configures alarm falling threshold. |
| <base_URI>/config/running/rmon/alarm/{alarm-index} | <alarm><owner>(string)</owner></alarm> | Configures alarm owner. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/rmon/event/{event-index} | <description>(string)</description> | Configures RMON event description. |
| <base_URI>/config/running/rmon/event/{event-index}/log | <log>(string)</log> | Configures event log. |
| <base_URI>/config/running/rmon/event/{event-index}/trap | <trap>(string)</trap> | Configures event trap. |
| <base_URI>/config/running/rmon/event/{event-index}/owner | <owner>(string)</owner> | Configures event owner. |
| <base_URI>/config/running/rmon/alarm/{alarm-index}/owner | <owner>(string)</owner> | Configures alarm owner. |
| DELETE URIs |
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/rmon/event/200/description
None
<description xmlns="urn:brocade.com:mgmt:brocade-rmon" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/rmon/event/200/description">hi_32768</description>
The following example uses the POST option to configure alarm.
<alarm> <alarm-index>100</alarm-index> <snmp-oid>1.3.6.1.2.1.16.1.1.1.5.65535</snmp-oid> <interval>10</interval> <type>absolute</type> <rising-threshold>10000</rising-threshold> <event>100</event> </alarm>
None
The following example uses the DELETE option to remove RMON event.
http://host:80/rest/config/running/rmon/event/100
None
None
