Configures, modifies, or retrieves Open Shortest Path First (OSPF) configurations.
| URI | Description |
| <base_URI>/config/running/router/ospf | Open Shortest Path First (OSPF). |
| GET URIs | Description |
| <base_URI>/config/running/router/ospf | Retrieves OSPF configuration details. |
| <base_URI>/config/running/router/ospf/{vrf-name} | Retrieves OSPF configuration details for a particular VRF. |
| <base_URI>/config/running/router/ospf/{vrf-name}/database-overflow-interval | Retrieves database overflow interval. |
| <base_URI>/config/running/router/ospf/{vrf-name}/default-information-originate | Retrieves default route information |
| <base_URI>/config/running/router/ospf/{vrf-name}/default-passive-interface | Marks all OSPF interfaces passive by default. |
| <base_URI>/config/running/router/ospf/{vrf-name}/default-metric | Specifies the OSPF routing protocol metric value. |
| <base_URI>/config/running/router/ospf/{vrf-name}/external-lsdb-limit | Retrieves External Link State Database limit. |
| <base_URI>/config/running/router/ospf/{vrf-name}/log | Enables logging for OSPFv3 activities. |
| <base_URI>/config/running/router/ospf/{vrf-name}/metric-type | Displays Metric type (Type 1 or Type 2). |
| <base_URI>/config/running/router/ospf/{vrf-name}/neighbor/{neighbor-addr} | Displays non-broadcast neighbor IP Address in the format A.B.C.D. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute | Enables route redistribution. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/connected | Redistributes directly connected routes. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/connected/route-map | Redistributes directly connected routes and specifies a route map to be consulted before a route is added to the routing table. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/static | Redistributes static routes. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/static/route-map | Redistributes static routes and specifies a route map to be consulted before a route is added to the routing table. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/bgp | Redistributes BGP routes. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/bgp/route-map | Redistributes BGP routes and specifies a route map to be consulted before a route is added to the routing table. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/ospf | Redistributes OSPF routes. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/isis | Redistributes IS-IS routes. |
| <base_URI>/config/running/router/ospf/{vrf-name}/redistribute/isis/route-map | Redistribute IS-IS routes and specifies a route map to be consulted before a route is added to the routing table. |
| <base_URI>/config/running/router/ospf/{vrf-name}/area/{area-id} | Displays the OSPF Router Area ID. |
| <base_URI>/config/running/router/ospf/{vrf-name}/auto-cost | Calculates OSPF interface cost according to bandwidth. |
| <base_URI>/config/running/router/ospf/{vrf-name}/distance/{route-type} | Configures an administrative distance value for OSPF routes. |
| <base_URI>/config/running/router/ospf/{vrf-name}/distribute-list | Prevents routes from being learnt by OSPF. |
| <base_URI>/config/running/router/ospf/{vrf-name}/distribute-list/route-map | Creates a route-map distribution list. |
| <base_URI>/config/running/router/ospf/{vrf-name}/distribute-list/route-map/in | Creates a distribution list for an inbound route map. |
| <base_URI>/config/running/router/ospf/{vrf-name}/max-metric | Retrieves Stub Router Advertisement. |
| <base_URI>/config/running/router/ospf/{vrf-name}/max-metric/router-lsa | Retrieves the maximum metric advertisement in the Router. |
| <base_URI>/config/running/router/ospf/{vrf-name}/summary-address/{sum-address},{sum-address-mask} | Retrieves IP address summaries information. |
| <base_URI>/config/running/router/ospf/{vrf-name}/timers | Retrieves routing timers information. |
| <base_URI>/config/running/router/ospf/{vrf-name}/maximum-paths | Changes the maximum number of OSPF shared paths. |
| <base_URI>/config/running/router/ospf/{vrf-name} /graceful-restart/ | Retrieves graceful restart information. |
| <base_URI>/config/running/router/ospf/{vrf-name}/graceful-restart/helper-disable | Disables graceful restart helper capability. |
| <base_URI>/config/running/router/ospf/{vrf-name}/nonstop-routing | Enables nonstop-routing (NSR). |
| POST URIs | Payload | Description |
| <base_URI>/config/running/router/ospf/(vrf-name)/database-overflow-interval | <database-overflow-interval>(unit32)</database-overflow-interval> | Configures database overflow interval. |
| <base_URI>/config/running/router/ospf/(vrf-name)/default-passive-interface | <default-passive-interface>(enumeration)</default-passive-interface> | Configures default passive interface. |
| <base_URI>/config/running/router/ospf/(vrf-name)/default-metric | <default-metric>(unit32)</default-metric> | Configures default matric value. |
| <base_URI>/config/running/router/ospf/(vrf-name)/neighbor | <neighbor><neighbor-addr>(ip-address)</neighbor-addr></neighbor> | Configures neighbor. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/router/ospf/(vrf-name)/default-information-originate | <default-information-originate><metric>(unit32)</metric><metric-type>(string)</metric-type> <route-map>(string)</route-map></default-information- originate> | Originates default-information. |
| <base_URI>/config/running/router/ospf/(vrf-name)/database-overflow-interval | <database-overflow-interval>(unit32)</database-overflow-interval> | Configures the time interval at which the device checks to see if the overflow condition has been eliminated. |
| <base_URI>/config/running/router/ospf/default- vrf/default-passive-interface | <default-passive-interface>(enumeration)</default-passive-interface> | Marks all OSPF interfaces passive by default. |
| <base_URI>/config/running/router/ospf/(vrf-name)/external-lsdb-limit | <external-lsdb-limit>(unit32)</external-lsdb-limit> | Configures the maximum size of the external LSDB. |
| <base_URI>/config/running/router/ospf/default- vrf/neighbor/ | <neighbor><neighbor-addr>(ip-address)</neighbor-addr></neighbor> | Configures the IPv4 address of the neighbor. |
| <base_URI>/config/running/router/ospf/default- vrf/redistribute | <redistribute><connected></connected></redistribute> | Redistributes directly connected routes. |
| <base_URI>/config/running/router/ospf/default- vrf/redistribute | <redistribute><static></static></redistribute> | Enables Static routes. |
| <base_URI>/config/running/router/ospf/(vrf-name)/redistribute | <redistribute><bgp></bgp></redistribute> | Enables BGP routes. |
| <base_URI>/config/running/router/ospf/(vrf-name)/redistribute | <redistribute><isis><level-1></level-1></isis></redistribute> | Enables ISIS routes |
| <base_URI>/config/running/router/ospf/(vrf-name)/area | <area><area-id>(unit32)</area-id></area> | Configures the area address. |
| <base_URI>/config/running/router/ospf/(vrf-name)/area | <area><area-id>(unit32)</area-id><nssa><nssa-value>(unit32)</nssa-value></nssa></area> | Configures an NSSA area. |
| <base_URI>/config/running/router/ospf/(vrf-name)/auto-cost | <auto-cost ><reference-bandwidth><ref-bandwidth>(unit32)</ref-bandwidth></reference-bandwidth></auto-cost> | Configures the reference bandwidth in Mbps. |
| <base_URI>/config/running/router/ospf/(vrf-name)/auto-cost | <auto-cost ><reference-bandwidth><use-active-ports></use-active-ports></reference-bandwidth></auto-cost> | When set, any dynamic change in bandwidth immediately affects the cost of OSPF routes. This parameter enables cost calculation for currently active ports only. |
| <base_URI>/config/running/router/ospf/(vrf-name)/distance | <distance><route-type>(enumeration)</route-type><dist-value>(unit32)</dist-value></distance> | Sets the route-type and distance value. |
| <base_URI>/config/running/router/ospf/(vrf-name)/graceful-restart | <graceful-restart><graceful-restart-enable>(enumeration)</graceful-restart-enable></graceful-restart> | Enables the OSPF Graceful Restart (GR) capability. |
| <base_URI>/config/running/router/ospf/(vrf-name)/graceful-restart | <graceful-restart><helper-disable>(enumeration)</helper-disable></graceful-restart> | Disables the GR helper capability. |
| <base_URI>/config/running/router/ospf/(vrf-name)/graceful-restart | <graceful-restart><restart-time>(unit32)</restart-time></graceful-restart> | Specifies the maximum restart wait time, in seconds, advertised to neighbors. |
| <base_URI>/config/running/router/ospf/(vrf-name) | <ospf><nonstop-routing>(enumeration)</nonstop-routing></ospf> | Enables nonstop-routing (NSR). |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/router/ospf/default- vrf/database-overflow-interval | <database-overflow-interval>(unit32)</database-overflow-interval> | Configures the time interval at which the device checks to see if the overflow condition has been eliminated. |
| <base_URI>/config/running/router/ospf/(vrf-name)/default-metric | <default-metric>(unit32)</default-metric> | Configures default metric value. |
| <base_URI>/config/running/router/ospf/(vrf-name)/external- lsdb-limit | <external-lsdb-limit>(unit32)</external-lsdb-limit> | Configures the maximum size of the external LSDB. |
| <base_URI>/config/running/router/ospf/(vrf-name)/log | <log><all>(enumeration)</all></log> | Configures logging. |
| <base_URI>/config/running/router/ospf/(vrf-name)/log | <log><database>(enumeration)</database></log> | Configures database logging. |
| <base_URI>/config/running/router/ospf/(vrf-name)/log | <log><retransmit>(enumeration)</retransmit></log> | Configures retransmission logging. |
| <base_URI>/config/running/router/ospf/(vrf-name)/log | <log><adjacency></adjacency></log> | Configures adjacency logging. |
| <base_URI>/config/running/router/ospf/default- vrf/neighbor | <neighbor><neighbor-addr>(ip-address)</neighbor-addr></neighbor> | Configures the IPv4 address of the neighbor. |
| <base_URI>/config/running/router/ospf/(vrf-name)/redistribute | <redistribute><static></static></redistribute> | Enables Static routes. |
| <base_URI>/config/running/router/ospf/default- vrf/redistribute | <redistribute><isis><level-1></level-1></isis></redistribute> | Enables ISIS routes |
| <base_URI>/config/running/router/ospf/(vrf-name)/graceful-restart/graceful-restart-enable | <graceful-restart-enable>(enumeration)</graceful-restart-enable> | Enables the OSPF Graceful Restart (GR) capability. |
| <base_URI>/config/running/router/ospf/(vrf-name)/graceful-restart/helper-disable | <helper-disable>(enumeration)</helper-disable> | Disables the GR helper capability. |
| <base_URI>/config/running/router/ospf/(vrf-name)/graceful-restart/restart-time | <restart-time>(unit32)</restart-time> | Specifies the maximum restart wait time, in seconds, advertised to neighbors. |
| DELETE URIs |
| <base_URI>/config/running/router/ospf/(vrf-name)/area/ |
| <base_URI>/config/running/router/ospf/(vrf-name)/nonstop-routing |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/router/ospf/vrf/(vrf-name)
None
<ospf xmlns="urn:brocade.com:mgmt:brocade-ospf" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/router/ospf/default-vrf">
<vrf>default-vrf</vrf>
<database-overflow-interval>111</database-overflow-interval>
<default-information-originate y:self="/rest/config/running/router/ospf/default-vrf/default-information-originate">
</default-information-originate>
<default-passive-interface>true</default-passive-interface>
<default-metric>555</default-metric>
<ldp-sync y:self="/rest/config/running/router/ospf/default-vrf/ldp-sync">
</ldp-sync>
<external-lsdb-limit>444</external-lsdb-limit>
<log y:self="/rest/config/running/router/ospf/default-vrf/log">
<all>true</all>
</log>
<neighbor y:self="/rest/config/running/router/ospf/default-vrf/neighbor/1.1.1.1">
<neighbor-addr>1.1.1.1</neighbor-addr>
</neighbor>
<redistribute y:self="/rest/config/running/router/ospf/default-vrf/redistribute">
<connected y:self="/rest/config/running/router/ospf/default-vrf/redistribute/connected">
</connected>
<static y:self="/rest/config/running/router/ospf/default-vrf/redistribute/static">
</static>
<bgp y:self="/rest/config/running/router/ospf/default-vrf/redistribute/bgp">
</bgp>
<ospf y:self="/rest/config/running/router/ospf/default-vrf/redistribute/ospf">
</ospf>
<isis y:self="/rest/config/running/router/ospf/default-vrf/redistribute/isis">
</isis>
</redistribute>
<rfc1583-compatibility y:self="/rest/config/running/router/ospf/default-vrf/rfc1583-compatibility">
<rfc1583-compatibility-flag>true</rfc1583-compatibility-flag>
</rfc1583-compatibility>
<area y:self="/rest/config/running/router/ospf/default-vrf/area/0">
<area-id>0</area-id>
<normal>true</normal>
<nssa y:self="/rest/config/running/router/ospf/default-vrf/area/0/nssa">
</nssa>
<stub y:self="/rest/config/running/router/ospf/default-vrf/area/0/stub">
</stub>
<prefix-list y:self="/rest/config/running/router/ospf/default-vrf/area/0/prefix-list">
</prefix-list>
</area>
<area y:self="/rest/config/running/router/ospf/default-vrf/area/1">
<area-id>1</area-id>
<nssa y:self="/rest/config/running/router/ospf/default-vrf/area/1/nssa">
</nssa>
<stub y:self="/rest/config/running/router/ospf/default-vrf/area/1/stub">
</stub>
<prefix-list y:self="/rest/config/running/router/ospf/default-vrf/area/1/prefix-list">
<prefix-list>abcd</prefix-list>
<in>true</in>
<out>true</out>
</prefix-list>
</area>
<area y:self="/rest/config/running/router/ospf/default-vrf/area/2">
<area-id>2</area-id>
<nssa y:self="/rest/config/running/router/ospf/default-vrf/area/2/nssa">
</nssa>
<stub y:self="/rest/config/running/router/ospf/default-vrf/area/2/stub">
<stub-value>11</stub-value>
</stub>
<prefix-list y:self="/rest/config/running/router/ospf/default-vrf/area/2/prefix-list">
</prefix-list>
</area>
<area y:self="/rest/config/running/router/ospf/default-vrf/area/3">
<area-id>3</area-id>
<nssa y:self="/rest/config/running/router/ospf/default-vrf/area/3/nssa">
<nssa-value>22</nssa-value>
</nssa>
<stub y:self="/rest/config/running/router/ospf/default-vrf/area/3/stub">
</stub>
<prefix-list y:self="/rest/config/running/router/ospf/default-vrf/area/3/prefix-list">
</prefix-list>
</area>
<auto-cost y:self="/rest/config/running/router/ospf/default-vrf/auto-cost">
<reference-bandwidth y:self="/rest/config/running/router/ospf/default-vrf/auto-cost/reference-bandwidth">
<ref-bandwidth>1000</ref-bandwidth>
<use-active-ports>true</use-active-ports>
</auto-cost>
<distance y:self="/rest/config/running/router/ospf/default-vrf/distance/external">
<route-type>external</route-type>
<dist-value>50</dist-value>
</distance>
<distance y:self="/rest/config/running/router/ospf/default-vrf/distance/inter-area">
<route-type>inter-area</route-type>
<dist-value>61</dist-value>
</distance>
<distance y:self="/rest/config/running/router/ospf/default-vrf/distance/intra-area">
<route-type>intra-area</route-type>
<dist-value>72</dist-value>
</distance>
<distribute-list y:self="/rest/config/running/router/ospf/default-vrf/distribute-list">
<route-map y:self="/rest/config/running/router/ospf/default-vrf/distribute-list/route-map">
<route-map>afgh</route-map>
<in>true</in>
</route-map>
</distribute-list>
<max-metric y:self="/rest/config/running/router/ospf/default-vrf/max-metric">
<router-lsa y:self="/rest/config/running/router/ospf/default-vrf/max-metric/router-lsa">
<external-lsa y:self="/rest/config/running/router/ospf/default-vrf/max-metric/router-lsa/external-lsa">
<external-lsa-val>16777214</external-lsa-val>
</external-lsa>
<summary-lsa y:self="/rest/config/running/router/ospf/default-vrf/max-metric/router-lsa/summary-lsa">
</summary-lsa>
<link y:self="/rest/config/running/router/ospf/default-vrf/max-metric/router-lsa/link">
<ptp>true</ptp>
<stub>true</stub>
<transit>true</transit>
</link>
<on-startup y:self="/rest/config/running/router/ospf/default-vrf/max-metric/router-lsa/on-startup">
<time>400</time>
<external-lsa y:self="/rest/config/running/router/ospf/default-vrf/max-metric/router-lsa/on-startup/external-lsa">
</external-lsa>
<summary-lsa y:self="/rest/config/running/router/ospf/default-vrf/max-metric/router-lsa/on-startup/summary-lsa">
</summary-lsa>
<link y:self="/rest/config/running/router/ospf/default-vrf/max-metric/router-lsa/on-startup/link">
</link>
</on-startup>
</router-lsa>
</max-metric>
<summary-address y:self="/rest/config/running/router/ospf/default-vrf/summary-address/12.0.0.0%2C255.0.0.0">
<sum-address>12.0.0.0</sum-address>
<sum-address-mask>255.0.0.0</sum-address-mask>
</summary-address>
<timers y:self="/rest/config/running/router/ospf/default-vrf/timers">
<lsa-group-pacing>300</lsa-group-pacing>
<throttle y:self="/rest/config/running/router/ospf/default-vrf/timers/throttle">
<spf y:self="/rest/config/running/router/ospf/default-vrf/timers/throttle/spf">
<init-delay>1000</init-delay>
<hold-time>2000</hold-time>
<max-hold-time>5000</max-hold-time>
</spf>
</throttle>
</timers>
<graceful-restart y:self="/rest/config/running/router/ospf/default-vrf/graceful-restart">
<graceful-restart-enable>true</graceful-restart-enable>
</graceful-restart>
<maximum-paths>9</maximum-paths>
</ospf>
The following is an example of the POST operation to add a prefix-list to router OSPF area configuration.
http://host:80/rest/config/running/router/ospf/(vrf-name)/area/1/prefix-list
<prefix-list>prefixlist1</prefix-list>
None
The following is an example of the DELETE operation to remove the prefix-list configuration.
None
None
