Configures Port-channel interface.
| URI | Description |
| <base_URI>/config/running/interface/Port-channel/{name} | Configures the list of port-channels. |
| GET URIs | Description |
| <base_URI>/config/running/interface/Port-channel/{name} | Retrieves the pot channel. |
| <base_URI>/config/running/interface/Port-channel/{name}/speed | Retrieves speed of the port. |
| <base_URI>/config/running/interface/Port-channel/{name}/description | Retrieves interface specific description. |
| <base_URI>/config/running/interface/Port-channel/{name}/shutdown | Shutdown the selected interface |
| <base_URI>/config/running/interface/Port-channel/{name}/minimum-links | Minimum number of links. |
| <base_URI>/config/running/interface/Port-channel/{name}/mtu | Sets mtu value to interface. |
| <base_URI>/config/running/interface/Port-channel/{name}/load-balance-type | Hash based load balancing |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/interface/Port-channel/{name}/speed | <speed>1000</speed> | Configures speed of the port. |
| <base_URI>/config/running/interface/Port-channel/{name}/description | <description>R1toR2</description> | Configures interface specific description. |
| <base_URI>/config/running/interface/Port-channel/{name}/shutdown | <shutdown>true</shutdown> | Configures the selected interface |
| <base_URI>/config/running/interface/Port-channel/{name}/minimum-links | <minimum-links>2</minimum-links> | Configures minimum number of links. |
| <base_URI>/config/running/interface/Port-channel/{name}/mtu | <mtu>5000</mtu> | Sets mtu value to interface. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/Port-channel/{name} | <Port-channel><speed>1000</speed></Port-channel> | Configures speed of the port. |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Port-channel/101/speed
None
<speed xmlns="urn:brocade.com:mgmt:brocade-interface" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Port-channel/101/speed">1000</speed>
The following is an example of the PUT operation to configure interface specific description.
http://host:80/rest/config/running/interface/Port-channel/101/description
None
The following is an example of the DELETE operation to remove a port channel.
None
None
