Configures port link dampening {PLD}.
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-error-disable | Configures port link dampening {PLD}. Valid interface type: Ethernet. |
| GET URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-error-disable/wait-time-in-sec | Configures port link dampening {PLD} wait time. Valid interface type: Ethernet. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-error-disable | <link-error-disable><link-error-disable-entry>1}</link-error-disable-entry><sampling-time-in-sec>{unit32}</sampling-time-in-sec><wait-time-in-sec>{unit32}</wait-time-in-sec></link-error-disable> | Edits port link dampening configuration. Valid interface type: Ethernet. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-error-disable | <link-error-disable><link-error-disable-entry>1}</link-error-disable-entry><sampling-time-in-sec>{unit32}</sampling-time-in-sec><wait-time-in-sec>{unit32}</wait-time-in-sec></link-error-disable> | Updates port link dampening configuration. Valid interface type: Ethernet. |
GET, PUT, PATCH, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/ethernet/%221/1%22/link-error-disable
None
<link-error-disable xmlns="urn:brocade.com:mgmt:brocade-pld" xmlns:y="http://brocade.com/ns/ rest" y:self="/rest/config/running/interface/Ethernet/%221/1%22/link-error-disable"> <link-error-disable-entry>1</link-error-disable-entry> <sampling-time-in-sec>10</sampling-time-in-sec> <wait-time-in-sec>10</wait-time-in-sec> </link-error-disable>
The following example uses the PATCH option to update the configuration.
<link-error-disable> <link-error-disable-entry>1</link-error-disable-entry> <sampling-time-in-sec>10</sampling-time-in-sec> <wait-time-in-sec>10</wait-time-in-sec> </link-error-disable>
None
