Displays information on the LDP session.
| URI | Description |
| <base-URI>/operational-state/mpls-state/ldp/ldp-session | Displays information on the LDP session. |
| <base_URI>operational-state/mpls-state/ldp/ldp-session/(ip-address) | Displays the LDP session IP address. |
| <base_URI>/operational-state/mpls-state/ldp/ldp-session/ip/session-ldp-stats | Displays LDP session status. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
http://host:80/rest/operational-state/mpls-state/ldp/ldp-session
None
<ldp-session xmlns="urn:brocade.com:mgmt:brocade-mpls-operational" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/operational-state/mpls-state/ldp/ldp-session/4.4.3.2:0">
<peer-ldp-id>4.4.3.2:0</peer-ldp-id>
<peer-lblspc-id>""</peer-lblspc-id>
<state>Operational</state>
<adjacency>Targeted</adjacency>
<role>Passive</role>
<max-hold>36</max-hold>
<time-left>31</time-left>
<session-status>Up</session-status>
<local-ldp-id>1.2.3.4:0</local-ldp-id>
<local-lblspc-id>""</local-lblspc-id>
<next-keepalive>3</next-keepalive>
<entity-index>2</entity-index>
<targeted-adj-added>Yes</targeted-adj-added>
<is-retry>false</is-retry>
<next-retry>0</next-retry>
<keepalive-interval>6000</keepalive-interval>
<local-keepalive-timeout>36</local-keepalive-timeout>
<peer-proposed-keepalive-timeout>36</peer-proposed-keepalive-timeout>
<session-up-time>"22 hr 44 min 19 sec "</session-up-time>
<tcp-conn-local>1.2.3.4:646</tcp-conn-local>
<tcp-conn-remote>4.4.3.2:13603</tcp-conn-remote>
<tcp-state>ESTABLISHED</tcp-state>
<num-fecs-received-from-peer>251</num-fecs-received-from-peer>
<num-fecs-installed-from-peer>250</num-fecs-installed-from-peer>
<is-fecs-pending-uninstall>false</is-fecs-pending-uninstall>
<num-fecs-filtered-out>0</num-fecs-filtered-out>
<num-fecs-filtered-in>0</num-fecs-filtered-in>
<filter-prefix-list-exists>false</filter-prefix-list-exists>
<is-only-gr-valid>false</is-only-gr-valid>
<gr-enabled>false</gr-enabled>
<peer-reconnect-time>0</peer-reconnect-time>
<peer-recovery-time>0</peer-recovery-time>
<reconnect-time-in-use>0</reconnect-time-in-use>
<reconnect-time-remaining>0</reconnect-time-remaining>
<recovery-time-in-use>0</recovery-time-in-use>
<recovery-time-remaining>0</recovery-time-remaining>
<local-eol-unrecognized-notification>false</local-eol-unrecognized-notification>
<remote-eol-unrecognized-notification>false</remote-eol-unrecognized-notification>
<does-session-support-eol>false</does-session-support-eol>
<local-state>true</local-state>
<remote-state>false</remote-state>
<eol-notification-time>0</eol-notification-time>
<eol-notification-time-remaining>0</eol-notification-time-remaining>
<eol-tx-label-silence-time>0</eol-tx-label-silence-time>
<eol-tx-label-silence-time-remaining>0</eol-tx-label-silence-time-remaining>
<eol-rx-label-silence-time>1000</eol-rx-label-silence-time>
<eol-rx-label-silence-time-remaining>0</eol-rx-label-silence-time-remaining>
<filtered>enum=0</filtered>
<interfaces>(targeted)</interfaces>
<addresses>4.4.3.2 34.34.34.2 45.45.45.1</addresses>
<session-ldp-stats y:self="/rest/operational-state/mpls-state/ldp/ldp-session/4.4.3.2:0/session-ldp-stats">
<ldp-protocol-errors-instance-total y:self="/rest/operational-state/mpls-state/ldp/ldp-session/4.4.3.2:0/session-ldp-stats/
ldp-protocol-errors-instance-total">
</ldp-protocol-errors-instance-total>
<ldp-protocol-stats-instance-total y:self="/rest/operational-state/mpls-state/ldp/ldp-session/4.4.3.2:0/session-ldp-stats/
ldp-protocol-stats-instance-total">
</ldp-protocol-stats-instance-total>
</session-ldp-stats>
</ldp-session>
