Configures, modifies, or retrieves alias configuration.
| URI | Description |
| <base_URI>/config/running/alias-config | User and global alias |
| <base_URI>/config/running/alias-config/alias | Global alias. Refer to alias-config/alias for information |
| <base_URI>/config/running/alias-config/user | User alias. Refer to alias-config/user for information |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The DELETE operation is supported only on alias and user URIs.The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/alias-config
None
<alias-config xmlns="urn:brocade.com:mgmt:brocade-aaa" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/alias-config"> <alias y:self="/rest/config/running/alias-config/alias/alias1"/> <user y:self="/rest/config/running/alias-config/user/user0"/> </alias-config>
