Enables Address Resolution Protocol (ARP) suppression on the current VLAN, lessening ARP-related traffic within an IP Fabric.
| URI | Description |
| <base_URI>/config/running/interface/vlan/{vlan-number}/suppress-arp | Enables Address Resolution Protocol (ARP) suppression on the current VLAN. |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/vlan/8000/suppress-arp
None
<suppress-arp xmlns="urn:brocade.com:mgmt:brocade-arp" y:self="/rest/config/running/interface/Vlan/8000/suppress-arp"> <enable>true</enable> </suppress-arp>
