Configures, modifies, or retrieves the Internet Group Management Protocol (IGMP).
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp | Configures IGMP. Valid interface type: Ethernet. |
| GET URIs | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp | Retrieves IGMP. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/last-member-query-interval | Retrieves the IGMP last-member query interval for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/query-interval | Retrieves the IGMP query interval for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/query-max-response-time | Retrieves the maximum response time for IGMP queries for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/immediate-leave | Removes a group from the IGMP table immediately following receipt of a Leave Group request. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/version | Retrieves the IGMP version on a device. Valid interface type: Ethernet. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp | <static-group><igmpl3-sg-addr>{igmpl3-sg-addr}</igmpl3-sg-addr></static-group> | Configures the IGMP static group membership entries for a specific interface.Valid interface type: Ethernet. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp | "<igmp><last-member-query-interval>{unit32}</last-member-query-interval></igmp> | Configures the IGMP last-member query interval for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp | "<igmp><query-interval>{unit32}</query-interval></igmp> | Configures the IGMP query interval for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp | <igmp><query-max-response-time>{unit32}</query-max-response-time></igmp> | Configures the maximum response time for IGMP queries for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp | <igmp><immediate-leave>{enumeration}</immediate-leave></igmp> | Removes a group from the IGMP table immediately following receipValid interface type: Ethernet.t of a Leave Group request. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp | <igmp><version>{unit32}</version></igmp> | Configures the IGMP version on a device. Valid interface type: Ethernet. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/last-member-query-interval | <last-member-query-interval>{unit32}</last-member-query-interval> | Configures the IGMP last-member query interval for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/query-interval | <query-interval>{unit32}</query-interval> | Configures the IGMP query interval for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/query-max-response-time | "<query-max-response-time>{unit32}</query-max-response-time> | Configures the maximum response time for IGMP queries for an interface. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/immediate-leave | "<immediate-leave>{enumeration}</immediate-leave> | Removes a group from the IGMP table immediately following receipt of a Leave Group request. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/version | "<version>{unit32}</version> | Configures the IGMP version on a device. Valid interface type: Ethernet. |
| DELETE URIs |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/igmp/static-group/{igmpl3-sg-addr} |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Ethernet/%221/1%22/ip/igmp
None
<igmp xmlns="urn:brocade.com:mgmt:brocade-igmp" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ethernet/%223/12%22/ip/igmp"> <last-member-query-interval>2000</last-member-query-interval> <query-interval>200</query-interval> <query-max-response-time>20</query-max-response-time> <immediate-leave>true</immediate-leave> <version>3</version> </igmp>
The following is an example of the POST operation to configure the IGMP static group membership entries for a specific interface.
http://host:80/rest/config/running/interface/Ve/11/ip/igmp
<static-group><igmpl3-sg-addr>230.100.100.100</igmpl3-sg-addr></static-group>
None
The following is an example of the DELETE operation to remove managed config flag on a specified interface.
http://host:80/rest/config/running/interface/Ve/11/ip/igmp/last-member-query-interval
None
None
