Displays TM statistics.
| URI | Description |
| <base_URI>/operational-state/tm-state | Displays TM statistics. |
| <base_URI>/operational-state/tm-state/tmvoq | Displays VOQ information. |
| <base_URI>/operational-state/tm-state/tmvoqingvalegrvalprioval | Displays ingress, egress and priority. |
| <base_URI>/operational-state/tm-state/tmdevicestat | Displays device statistics. |
| <base_URI>/operational-state/tm-state/non-empty-voq | Displays non-empty voqs in the system. |
| <base_URI>/operational-state/tm-state/tmcpustatsslot | Displays TM voq stats for CPU port per slot. |
| <base_URI>/operational-state/tm-state/tmcpustatsslotallgrp | Displays TM voq stats for CPU port per slot for all CPU group. |
| <base_URI>/operational-state/tm-state/tm-top-discard-pkt-data | Displays TM voq stats to get list of top discarded packets. |
| <base_URI>/operational-state/tm-state/tm-top-max-queue-depth-data | Displays TM voq stats to get list of top max queue depth. |
| <base_URI>/operational-state/tm-state/tm-max-buff-util-data | Displays snapshot of maximum TM buffer utilization. |
| <base_URI>/operational-state/tmdevicestatscommon-state | Displays common TM device stats. |
| <base_URI>/operational-state/tm-state/tmvoqstatistics | Displays a summary of traffic management VOQ maximum queue depth statistics. |
| <base_URI>/operational-state/tm-state/cngn-mon-dev | Displays device monitoring information. |
| <base_URI>/operational-state/tm-state/cngn-mon-dev/discard-pkt-threshold | Displays discard packet monitoring threshold. |
| <base_URI>/operational-state/tm-state/cngn-mon-dev/discard-log-interval | Displays discard packet logging interval. |
| <base_URI>/operational-state/tm-state/cngn-mon-voq | Displays VOQ monitoring information. |
| <base_URI>/operational-state/tm-state/cngn-mon-voq/discard-voq-pkt-threshold | Displays VOQ discard packet monitoring threshold. |
| <base_URI>/operational-state/tm-state/cngn-mon-voq/discard-voq-log-interval | Displays VOQ discard packet logging interval. |
| <base_URI>/operational-state/tm-state/cngn-mon-del-pkt | Displays delete packet monitoring information. |
| <base_URI>/operational-state/tm-state/cngn-mon-del-pkt/delete-pkt-threshold | Displays delete packet monitoring threshold. |
| <base_URI>/operational-state/tm-state/cngn-mon-del-pkt/delete-log-interval | Displays delete packet logging interval. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
http://host:80//rest/operational-state/tm-state
