Configures MSTP.
| URI | Description |
| <base_URI>/config/running/protocol/spanning-tree/mstp | Configures MSTP. |
| GET URIs | Description |
| <base_URI>/config/running/protocol/spanning-tree | Retrieves spanning tree configurations. |
| <base_URI>/config/running/protocol/spanning-tree/mstp | Retrieves MSTP configuration information. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/instance/(instance-id) | Retrieves MSTP configuration information for a particular instance. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/protocol/spanning-tree/mstp | <instance><id>(unit32)</id><vlan>(unit32)</vlan></instance> | Configures MSTP instance. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/protocol/spanning-tree/mstp/instance/(instance-id)/priority | <priority>(unit32)</priority> | Configures MSTP priority. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/protocol/spanning-tree/mstp/description | <description>(string)</description> | Configures MSTP description. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/bridge-priority | <bridge-priority>(unit32)</bridge-priority> | Configures MSTP bridge priority. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/cisco-interoperability | <cisco-interoperability>(enumeration)</cisco-interoperability> | Enable MSTP cisco interoperability. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/error-disable-timeout/enable | <enable></enable> | Enables MSTP error disable timeout. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/forward-delay | <forward-delay>(unit32)</forward-delay> | Configures MSTP forward delay. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/hello-time | <hello-time>(unit32)</hello-time> | Configures MSTP hello time. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/max-age | <max-age>(unit32)</max-age> | Configures MSTP max age. |
| <base_URI>/config/running/protocol/spanning-tree | max-hops>(unit32)</max-hops> | Configures max hops. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/port-channel/path-cost | <path-cost>(string)</path-cost> | Configures MSTP port channel path cost. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/region | <region>(string)</region> | Configures MSTP string. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/revision | <revision>(unit32)</revision> | Configures MSTP revision. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/shutdown | <shutdown></shutdown> | Disable MSTP. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/transmit-holdcount | <transmit-holdcount>(uni32)</transmit-holdcount> | Configures MSTP trasmit holdcount. |
| <base_URI>/config/running/protocol/spanning-tree/mstp/error-disable-timeout/interval | <interval>(unit32)</interval> | Configures MSTP error disable timeout interval. |
| DELETE URIs |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/protocol/spanning-tree/mstp
None
<spanning-tree xmlns="urn:brocade.com:mgmt:brocade-xstp" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/protocol/spanning-tree">\r
<mstp y:self="/rest/config/running/protocol/spanning-tree/mstp">\r
<error-disable-timeout y:self="/rest/config/running/protocol/spanning-tree/mstp/error-disable-timeout">\r
</error-disable-timeout>\r
<port-channel y:self="/rest/config/running/protocol/spanning-tree/mstp/port-channel">\r
</port-channel>\r
<instance y:self="/rest/config/running/protocol/spanning-tree/mstp/instance/1">\r
<id>1</id>\r
<vlan>5-10</vlan>\r
</instance>\r
</mstp>\r
</spanning-tree>\r
The following example uses the POST option to configure MSTP instance.
<instance> <id>2</id> <vlan>4</vlan> </instance>
None
The following example uses the DELETE option to remove MSTP description.
http://host:80/rest/config/running/protocol/spanning-tree/mstp/description
None
None
