Displays counters per protocol
| URI | Description |
| <base_URI>/operational-state/app-telemetry-counters-state | Displays counters per protocol. |
Only GET operation is supported. Use of the Resource-Depth request header is recommended.
The following example shows the complete cURL command and server response for the
app-telemetry-counters-state GET operation.
http://host:80/rest/operational-state/app-telemetry-counters-state
curl -H "Accept: application/vnd.operational-state.resource+xml" -H "Resource-Depth: 6" -u "lab:Tester**" http://10.20.229.40:80/rest/operational-state/app-telemetry-counters-state
<data xmlns="http://brocade.com/ns/rest" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/operational-state"> <app-telemetry-counters-state xmlns="urn:brocade.com:mgmt:brocade-ssm-operational" y:self="/rest/operational-state/ app-telemetry-counters-state"> </app-telemetry-counters-state> </data>
| Release version | History |
| 18r.2.00 | This API call was introduced. |
