Configures, modifies, or retrieves TACACS+ server configuration.
| URI | Description |
| <base_URI>/config/running/tacacs-server | TACACS+ server. |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/tacacs-server
None
<tacacs-server xmlns="urn:brocade.com:mgmt:brocade-aaa" xmlns:y="http://brocade.com/ns/rest"
y:self="/rest/config/running/tacacs-server">
<host y:self="/rest/config/running/tacacs-server/host/10.20.38.100">
<hostname>10.20.38.100</hostname>
<use-vrf>mgmt-vrf</use-vrf>
<port>55</port>
<protocol>pap</protocol>
<key>"Yf0BKEhsc83gp+kIoGMQ/g==\n"</key>
<encryption-level>7</encryption-level>
<retries>6</retries>
<timeout>10</timeout>
</host>
<source-ip>chassis-ip</source-ip>
</tacacs-server>
The following is an example of the POST operation to add a new host to the TACACS+ server.
<host> <hostname>10.20.38.110</hostname> </host>
None
The following is an example of the DELETE operation to remove a host name from the TACACS+ server.
http://host:80/rest/config/running/tacacs-server/host/10.20.38.110
None
None
