Media types identify the form of the data contained within a resource representation.
Media type is an application-specific format with a well-defined name represented in the form of an identifier. Media types are specified in the Accept and Content-Type header's value for the request and the response respectively.
Media types are specific to resources, allowing them to change independently and support formats that other resources do not.
| Media type | Resources |
| application/vnd.base.resource+xml | Represents the high-level base resources such as configuration datastore and operational state resource. |
| application/vnd.configuration.resource+xml | Represents resources defined for the configuration command derived from a YANG module. |
| application/vnd.operational-state.resource+xml | Represents the operational-state resources defined in the YANG model |
| application/vnd.operations.resource+xml | Represents the defined YANG-RPC operations. |
| application/vnd.base.resource+json | Represents the high-level base resources such as configuration datastore and operational state resource. |
| application/vnd.configuration.resource+json | Represents resources defined for the configuration command derived from a YANG module. |
| application/vnd.operational-state.resource+json | Represents the operational-state resources defined in the YANG model |
| application/vnd.yang.operation+json | Represents the defined YANG-RPC operations. |
