Configures, retrieves, and modifies Link Fault Signaling (LFS).
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-fault-signaling | Configures LFS. Valid interface type: Ethernet. |
| GET URIs | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-fault-signaling | Retrieves LFS. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-fault-signaling/tx | Retrieves TX LFS. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-fault-signaling/rx | Retrieves RX LFS. Valid interface type: Ethernet. |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-fault-signaling/rx | <rx>(enumeration)</rx> | Configures RX LFS. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/link-fault-signaling/tx | <tx>(enumeration)</rx> | Configures TX LFS. Valid interface type: Ethernet. |
| PUT URIs | Payload | Description |
| DELETE URIs |
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Ethernet/%226/57%22//link-fault-signaling
None
<link-fault-signaling xmlns="urn:brocade.com:mgmt:brocade-lfs" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ethernet/%226/57%22/link-fault-signaling"> <rx>on</rx> <tx>on</tx> </link-fault-signaling>
The following example uses the PATCH option to configure RX LFS.
http://host:80/rest/config/running/interface/Ethernet/%226/57%22//link-fault-signaling/rx
<rx>on</rx>
None
The following example uses the DELETE option to remove TX LFS.
http://host:80/rest/config/running/interface/Ethernet//%226/57%22//link-fault-signaling/tx
None
None
