get-stp-brief-info
Displays spanning tree information.
Resource URIs
| URI
Description
| <base_URI>/operations/get-stp-brief-info
Parameters
- stp-mode
- Displays the type of the Spanning Tree Protocol configured on the switch.
- priority
- Displays the Bridge priority.
- hello-time
- Displays the interval between two transmissions of BPDU packets sent by the Root Bridge to tell all other switches that it is indeed the Root Bridge (1 to 10 sec).
- max-age
- Displays the Max Age may be set to ensure that old information does not endlessly circulate through redundant paths in the network, preventing the effective propagation of new information (6 to 40 sec).
- forward-delay
- Displays the port on the Switch spends this time in the listening state while moving from the blocking state to the forwarding state (4 to 30 sec).
- interface-type
- Displays the interface type.
- interface-name
- Displays the interface name.
- spanningtree-enabled
- Enables spanning tree.
- if-index
- Displays the interface index.
- interface-id
- Displays the interface ID.
- if-role
- Displays the interface role.
- if-state
- Displays the interface state.
- external-path-cost
- Designated external path cost.
- internal-path-cost
- Designated internal path cost.
- configured-path-cost
- Displays the configured path cost.
- designated-port-id
- Displays the designated port ID.
- port-priority
- Displays the Port priority.
- designated-bridge-id
- Displays the designated bridge ID.
- port-hello-time
- Displays the Port hello time.
- forward-transitions-count
- Displays the number of forward transitions.
- received-stp-type
- Displays the received (rx) STP type.
- transmitted-stp-type
- Displays the transmitted (tx) STP type.
- edge-port
- Displays the edge port mode.
- auto-edge
- Displays the auto edge.
- admin-edge
- Displays the admin edge.
- edge-delay
- Displays the edge delay.
- configured-root-guard
- Displays the configured root guard.
- oper-root-guard
- Displays the operational root guard.
- boundary-port
- Displays the Is boundary.
- oper-bpdu-guard
- Displays the operational BPDU guard.
- oper-bpdu-filter
- Displays the operational BPDU filter.
- link-type
- Displays the spanning tree link type.
- rx-bpdu-count
- Displays the received BPDU count.
- tx-bpdu-count
- Displays the transmitted BPDU count.
Usage Guidelines
Only POST operation is supported.
URI
http://host:80/rest/operations/get-stp-brief-info
<get-stp-brief-info></get-stp-brief-info>
<output xmlns='urn:brocade.com:mgmt:brocade-xstp-ext'>
<spanning-tree-info>
<stp-mode>stp</stp-mode>
<stp>
<root-bridge>
<priority>32768</priority>
<bridge-id>8000.01e0.5200.0193</bridge-id>
<hello-time>2</hello-time>
<max-age>20</max-age>
<forward-delay>15</forward-delay>
</root-bridge>
<bridge>
</bridge>
</stp>
</spanning-tree-info>
<has-more>false</has-more>
</output>
