Configures, modifies, or retrieves FRU mail settings.
| URI | Description |
| <base_URI>/config/running/system-monitor-mail | Configures the FRU email alerts. |
| <base_URI>/config/running/system-monitor-mail/fru | FRU mail settings. Refer to system-monitor-mail/fru for more information. |
| <base_URI>/config/running/system-monitor-mail/interface | Interface mail settings. Refer to system-monitor-mail/interface for more information. |
| <base_URI>/config/running/system-monitor-mail/relay | Relay IP mail settings. Refer to system-monitor-mail/relay for more information. |
| <base_URI>/config/running/system-monitor-mail/security | Security mail settings. Refer to system-monitor-mail/security for more information. |
| <base_URI>/config/running/system-monitor-mail/sfp | SFP mail settings. Refer to system-monitor-mail/sfp for more information. |
| POST URI | Payload | Description |
| /rest/config/running/system-monitor-mail | <relay><host-ip>{inet:host}</host-ip></relay> | Creates FRU email alerts. |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/system-monitor-mail
None
<system-monitor-mail xmlns="urn:brocade.com:mgmt:brocade-system-monitor" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/system-monitor-mail"> <fru y:self="/rest/config/running/system-monitor-mail/fru"/> <sfp y:self="/rest/config/running/system-monitor-mail/sfp"/> <security y:self="/rest/config/running/system-monitor-mail/security"/> <interface y:self="/rest/config/running/system-monitor-mail/interface"/> <relay y:self="/rest/config/running/system-monitor-mail/relay/10.20.38.100"/> </system-monitor-mail>
