Configures, modifies, or retrieves role configurations.
| URI | Description |
| <base_URI>/config/running/role | Role configuration. |
| <base_URI>/config/running/role/name | Name of the role. |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/role
None
<role xmlns="urn:brocade.com:mgmt:brocade-aaa" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/role">
<name y:self="/rest/config/running/role/name/admin">
<name>admin</name>
<desc>Administrator</desc>
</name>
<name y:self="/rest/config/running/role/name/admin2">
<name>admin2</name>
</name>
<name y:self="/rest/config/running/role/name/trial">
<name>trial</name>
</name>
<name y:self="/rest/config/running/role/name/user">
<name>user</name>
<desc>User</desc>
</name>
</role>
The following is an example of the POST operation to add a role name and description.
<name>
<name>user3</name>
<desc>user</desc>
</name>
None
The following is an example of the DELETE operation to remove a user.
http://host:80/rest/config/running/role/name/user3
None
None
