Configures Proxy-Arp on the interface.
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/proxy-arp | Configures Proxy-ARP on the interface. Valid interface types: Ethernet, Ve. |
| GET URIs | Description |
| PATCH URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ip/proxy-arp | <proxy-arp>true</proxy-arp> | Enables Proxy-ARP on interface. Valid interface types: Ethernet, Ve. |
| PUT URIs | Payload | Description |
| DELETE URIs |
GET, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running//interface/ethernet/%223/14%22/ip/proxy-arp
None
<proxy-arp xmlns="urn:brocade.com:mgmt:brocade-ip-config" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ethernet/%223/14%22/ip/proxy-arp">true</proxy-arp>
The following example uses the PATCH option to configure Proxy-ARP on Ethernet interface.
None
The following example uses the DELETE option to remove Proxy-ARP from Ethernet interface.
None
None
