Configures RMON ethernet statistics collection.
| URI | Description |
| <base_URI>/config/running/interface/(interface-type}/{interface-name}/rmon/collection | Configures RMON ethernet collection statistics. Valid interface type: Ethernet. |
| GET URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection/stats/{ether-stats-index}/owner | Displays RMON ether statistics collection owner identity. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/buckets | Displays the number of buckets for the RMON collection history. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/interval | Displays the polling interval. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/owner | Displays RMON history index owner identity. Valid interface type: Ethernet. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection | <stats><ether-stats-index>{int32}</ether-stats-index></stats> | Configures RMON collection statistics. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection | <history><history-control-index>{int32}</history-control-index></history> | Configures RMON collection history. Valid interface type: Ethernet. |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection/stats/{ether-stats-index}/owner | <owner>{string}</owner> | Configures RMON ether statistics collection owner identity. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/buckets | <buckets>{unit32}</buckets> | Configures the number of buckets for the RMON collection history. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/interval | <interval>{unit32}</interval> | Configures polling interval. Valid interface type: Ethernet. |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/owner | <owner>{string}</owner> | Configures RMON history index owner identity. Valid interface type: Ethernet. |
| DELETE URIs |
| <base_URI>/config/running/interface/(interface-type}/{interface-name}/rmon/collection/stats/{ether-stats-index} |
| <base_URI>/config/running/interface/(interface-type}/{interface-name}/rmon/collection/stats/{ether-stats-index}/owner |
| <base_URI>/config/running/interface/(interface-type}/{interface-name}/rmon/collection/history/{history-control-index} |
| <base_URI>/config/running/interface/(interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/buckets |
| <base_URI>/config/running/interface/(interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/interval |
| <base_URI>/config/running/interface/(interface-type}/{interface-name}/rmon/collection/history/{history-control-index}/owner |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/rmon/interface/Ethernet/%222/13%22/rmon/collection/stats/65535/owner
None
<owner xmlns="urn:brocade.com:mgmt:brocade-rmon" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ethernet/%222/13%22/rmon/collection/stats/65535/owner">sk</owner>
The following example uses the POST option to configure RMON collection history.
<history><history-control-index>40</history-control-index></history>
None
The following example uses the DELETE option to remove owner identity.
http://host:80/rest/config/running/rmon/interface/Ethernet/%222/13%22/rmon/collection/stats/{ether-stats-index}/owner
None
None
