Configures, modifies, or retrieves the Internet Protocol version 6 (IPv6) access group.
| URI | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/access-group |
Configures IPv6 access group. Valid interface types: Ethernet, Port-channel, Ve |
| GET URIs | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/access-group/{ipv6-access-list},{ip-direction} | Retrieves IPv6 access group. Valid interface types: Ethernet, Port-channel, Ve, Management. |
| POST URIs | Payload | Description |
| <base_URI>/config/running/interface/{interface-type}/{interface-name}/ipv6/access-group | <access-group><ipv6-access-list>{acl-name}</ipv6-access-list><ip-direction>{direction}</ip-direction></access-group> | Configures an IPv6 access group. Valid interface types: Ethernet, Port-channel, Ve. |
| <base_URI>/config/running/ipv6/receive | <access-group><acl-name>{acl-name}</acl-name></access-group> | Configures IPv6 Receive Access group. |
| DELETE URIs |
| <base_URI>/config/running/ipv6/receive/access-group/{acl-name} |
GET, POST, PUT, PATCH, DELETE, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/interface/Ethernet/%222/2%22/ipv6/access-group/traf_ext3,in
None
<access-group xmlns="urn:brocade.com:mgmt:brocade-ipv6-access-list" xmlns:y="http://brocade.com/ns/rest" y:self="/rest/config/running/interface/Ethernet/%222/2%22/ipv6/access-group/traf_ext3%2Cin"> <ipv6-access-list>traf_ext3</ipv6-access-list> <ip-direction>in</ip-direction> </access-group>
The following is an example of the POST operation to add an access-group.
<access-group> <ipv6-access-list>traf_ext3</ipv6-access-list> <ip-direction>in</ip-direction> </access-group>
None
The following is an example of the DELETE operation to remove the access-group configuration.
None
None
