Configures, modifies, or retrieves login or command accounting configuration.
| URI | Description |
| <base_URI>/config/running/aaa/accounting | Login or command accounting |
| <base_URI>/config/running/aaa/accounting/commands | Enables or disabled command accounting |
| <base_URI>/config/running/aaa/accounting/exec | Enables or disables login accounting |
| PUT URIs | Payload | Description |
| <base_URI>/config/running/aaa/accounting/exec/default/start-stop/server-type | <server-type>{acc_srv_type}</server-type> | Enables login accounting. |
| <base_URI>/config/running/aaa/accounting/commands/default/start-stop/server-type | <server-type>{acc_srv_type}</server-type> | Enables command accounting. |
GET, OPTIONS, and HEAD operations are supported.
The following example uses the GET option to retrieve the configuration details.
http://host:80/rest/config/running/aaa/accounting
None
<accounting y:self="/rest/config/running/aaa/accounting">
<exec y:self="/rest/config/running/aaa/accounting/exec">
<default y:self="/rest/config/running/aaa/accounting/exec/default">
<start-stop y:self="/rest/config/running/aaa/accounting/exec/default/start-stop">
<server-type>none</server-type>
</start-stop>
</default>
</exec>
<commands y:self="/rest/config/running/aaa/accounting/commands">
<default y:self="/rest/config/running/aaa/accounting/commands/default">
<start-stop y:self="/rest/config/running/aaa/accounting/commands/default/start-stop">
<server-type>tacacs+</server-type>
</start-stop>
</default>
</commands>
</accounting>
