The user has the option of supplying the primary or secondary parameter for a normal LSP to reset only the primary or secondary path of the LSP.
To reset or clear a bypass RSVP LSP session complete the following steps.
device# configure
device(config)# router mpls
device(config-router-mpls)# clear mpls bypass-lsp test1
the following example clears the bypass RSVP LSP session for LSP test1.
device# configure device(config)# router mpls device(config-router-mpls)# clear mpls bypass-lsp test1
When the user resets an LSP with the clear mpls lsp command, the following information message displays:
"Disconnecting signaled LSP name" "Connecting signaled LSP name"
