Disabling the Record Route Function
An RRO consists of a series of sub-objects that can contain the addresses of the LSRs in the path. This information can be viewed with the show mpls lsp detail command. The path information is recorded in the RRO by default, but the user can disable path recording.
To disable path recording in the RRO, complete the following steps.
  1. enable the device for configuration.
    device# configure
  2. Enable the MPLS router.
    device(config)# router mpls
  3. Enable and configure the label switched path (LSP).
    device(config-router-mpls)# lsp tunnel1
    In this example, the selected LSP is named tunnel1.
  4. Disable the recording path routes.
    device(config-router-mpls-lsp-tunnel1)# no record
device# configure terminal
