Perform the following steps.
device# configure terminal
device(config)# interface ethernet 0/1
device(config-if-eth-0/1)# ip router isis
device(config-if-eth-0/1)# isis ldp-sync enable
device(config-if-eth-0/1)# ip ospf area 0.0.0.0
device(config-if-eth-0/1)# ip ospf ldp-sync enable
device# show isis interface Total number of IS-IS Interfaces: 5 Interface: eth 0/1 Circuit State: UP Circuit Mode: LEVEL-1-2 Circuit Type: BCAST Passive State: FALSE Circuit Number: 3, MTU: 1500 Level-1 Auth-mode: None Level-2 Auth-mode: None Level-1 Metric: 10, Level-1 Priority: 64 Level-1 Hello Interval: 10 Level-1 Hello Multiplier: 3 Level-1 Designated IS: R2-03 Level-1 DIS Changes: Level-2 Metric: 10, Level-2 Priority: 64 Level-2 Hello Interval: 10 Level-2 Hello Multiplier: 3 Level-2 Designated IS: R2-03 Level-2 DIS Changes: 2 Next IS-IS LAN Level-1 Hello in 7 seconds Next IS-IS LAN Level-2 Hello in 3 seconds Number of active Level-1 adjacencies: 0 Number of active Level-2 adjacencies: 0 Circuit State Changes: 1 Circuit Adjacencies State Changes: 0 Rejected Adjacencies: 0 Circuit Authentication L1 failures: 0 Circuit Authentication L2 failures: 0 Bad LSPs: 0 Control Messages Sent: 40 Control Messages Received: 0 Hello Padding: Enabled IP Enabled: TRUE IP Addresses: 10.30.30.2/28 IPv6 Enabled: FALSE MPLS TE Enabled: FALSE LDP-SYNC: Enabled, State:
device# show ip ospf OSPF Version Version 2 Router Id 10.1.1.2 ASBR Status No ABR Status No (0) Redistribute Ext Routes from Initial SPF schedule delay 0 (msecs) Minimum hold time for SPFs 0 (msecs) Maximum hold time for SPFs 0 (msecs) External LSA Counter 0 External LSA Checksum Sum 00000000 Originate New LSA Counter 9 Rx New LSA Counter 6 External LSA Limit 174762 Database Overflow Interval 0 Database Overflow State : NOT OVERFLOWED RFC 1583 Compatibility : Enabled Slow neighbor Flap-Action : Disabled, timer 300 Nonstop Routing: Disabled Graceful Restart: Disabled, timer 120 Graceful Restart Helper: Enabled LDP-SYNC: Globally enabled, Hold-down time 66 sec Interfaces with LDP-SYNC enabled: eth 0/1
The following example shows the previous steps.
device# configure terminal device(config)# interface e 0/1 device(config-if-eth-0/1)# ip router isis device(config-if-eth-0/1)# isis ldp-sync enable device(config-if-eth-0/1)# ip ospf area 0.0.0.0 device(config-if-eth-0/1)# ip ospf ldp-sync enable
