To display IP Information for a specified VRF, enter the following command at any level of the CLI.
        device# show vrf
Total number of VRFs configured: 1
Status Codes - A:active, D:pending deletion, I:inactive
Name                 Default RD 	 	 		 IFL ID  vrf|v4|v6 	 	 	 	 Routes Interfaces
a 						1:1 				131071   A | A| A 	 	 	 	 	 	 	 14
Total number of IPv4 unicast route for all non-default VRF is 12
Total number of IPv6 unicast route for all non-default VRF is 2
device# show vrf a
VRF a, default RD 1:1, Table ID 1 IFL ID 131071
Label: (Not Allocated),  Label-Switched Mode: OFF
IP Router-Id: 0.0.0.0
  No interfaces
  No Export VPN route-target communities
  No Import VPN route-target communities
  No import route-map
  No export route-map
  Address Family IPv4
    Max Routes: 5120
    Number of Unicast Routes: 12
Address Family IPv6
    Max Routes: 128
    Number of Unicast Routes: 2
      Syntax: show vrf vrf-name
The vrf-name parameter specifies the VRF that the user wants to display IP information for.
                 This field...  |
                 Displays...  |
                 VRF Name  |
                 The name of the VRF.  |
                 Default RD  |
                 The default route distinguisher for the VRF.  |
                 Table ID  |
                 The table ID for the VRF.  |
                 Routes  |
                 The total number of IPv4 and IPv6 Unicast routes configured on this VRF.  |
                 Label  |
                 Display the unique VRF label that has been assigned to the specified VRF.  |
                 Label Switched Mode  |
                 Displays when Label Switched Mode is ON or OFF.  |
                 Max routes  |
                 The maximum number of routes that can be configured on this VRF.  |
                 Number of Unicast Routes  |
                 The number of Unicast routes configured on this VRF.  |
                 Interfaces  |
                 The interfaces from this Extreme device that are configured within this VRF.  |
                 Export VPN route-target communities:  |
                 The export route-targets that are configured for this VRF.  |
                 Import VPN route-target communities  |
                 The import route-targets that are configured for this VRF.  |
                 Import route-map  |
                 The name of the import route-map when any that is configured for this VRF.  |
                 Export route-map  |
                 The name of the export route-map when a route-map has been configured for this VRF.  |
