To display CSPF fate-sharing group information for a specific CSPF group, use the show running-config router mpls cspf-group cspf-group name command. The output from the show running-config router mpls command. In the following example output, the CSPF fate-sharing group information is displayed for CSPF group gold.
device# show running-config router mpls cspf-group gold cspf-group gold penalty 65535 node 10.7.7.3 node 10.7.7.8
Fate-sharing group membership for any given TE link or node consists of its own membership to the group, and the TE node to which it belongs. The output from the show mpls te database detail command is enhanced to display the fate-sharing groups to which the TE links or nodes belong. In the following example output, node 10.20.20.20 displays fate-sharing group information for group1/100 and group2/10.
TE Router ID: 30.11.1.30 OSPF Area: 0.0.0.0 Node Id: (14.1.2.3), Type: Router P2P Link: From: 14.1.2.3 To: 13.13.13.13, Local: 13.14.1.14, Remote: 13.14.1.13, LSA Id: 16777313, Gen:927 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 1000000 kbits/sec Reservable BW: 1000000 kbits/sec Unreserved BW: [0] 1000000 kbits/sec [1] 1000000 kbits/sec [2] 1000000 kbits/sec [3] 1000000 kbits/sec [4] 1000000 kbits/sec [5] 1000000 kbits/sec [6] 1000000 kbits/sec [7] 1000000 kbits/sec P2P Link: From: 14.1.2.3 To: 13.13.13.13, Local: 13.14.20.14, Remote: 13.14.20.13, LSA Id: 16777314, Gen:916 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 1000000 kbits/sec Reservable BW: 1000000 kbits/sec Unreserved BW: [0] 1000000 kbits/sec [1] 1000000 kbits/sec [2] 1000000 kbits/sec [3] 1000000 kbits/sec [4] 1000000 kbits/sec [5] 1000000 kbits/sec [6] 1000000 kbits/sec [7] 1000000 kbits/sec P2P Link: From: 14.1.2.3 To: 19.19.19.19, Local: 19.14.1.14, Remote: 19.14.1.19, LSA Id: 16777223, Gen:934 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 10000000 kbits/sec Reservable BW: 10000000 kbits/sec Unreserved BW: [0] 10000000 kbits/sec [1] 10000000 kbits/sec [2] 10000000 kbits/sec [3] 10000000 kbits/sec [4] 10000000 kbits/sec [5] 10000000 kbits/sec [6] 10000000 kbits/sec [7] 10000000 kbits/sec P2P Link: From: 14.1.2.3 To: 57.57.57.57, Local: 14.57.1.14, Remote: 14.57.1.57, LSA Id: 16777241, Gen:886 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 10000000 kbits/sec Reservable BW: 10000000 kbits/sec Unreserved BW: [0] 10000000 kbits/sec [1] 10000000 kbits/sec [2] 10000000 kbits/sec [3] 10000000 kbits/sec [4] 10000000 kbits/sec [5] 10000000 kbits/sec [6] 10000000 kbits/sec [7] 10000000 kbits/sec Node Id: (4.4.4.4), Type: Router P2P Link: From: 4.4.4.4 To: 17.17.17.17, Local: 23.45.67.8, Remote: 23.45.67.17, LSA Id: 16777220, Gen:938 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 1000000 kbits/sec Reservable BW: 1000000 kbits/sec Unreserved BW: [0] 1000000 kbits/sec [1] 1000000 kbits/sec [2] 1000000 kbits/sec [3] 1000000 kbits/sec [4] 1000000 kbits/sec [5] 1000000 kbits/sec [6] 1000000 kbits/sec [7] 1000000 kbits/sec Node Id: (13.13.13.13), Type: Router P2P Link: From: 13.13.13.13 To: 14.1.2.3, Local: 13.14.1.13, Remote: 13.14.1.14, LSA Id: 16777218, Gen:928 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 1000000 kbits/sec Reservable BW: 1000000 kbits/sec Unreserved BW: [0] 1000000 kbits/sec [1] 1000000 kbits/sec [2] 1000000 kbits/sec [3] 1000000 kbits/sec [4] 1000000 kbits/sec [5] 1000000 kbits/sec [6] 1000000 kbits/sec [7] 1000000 kbits/sec P2P Link: From: 13.13.13.13 To: 14.1.2.3, Local: 13.14.20.13, Remote: 13.14.20.14, LSA Id: 16777219, Gen:915 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 1000000 kbits/sec Reservable BW: 1000000 kbits/sec Unreserved BW: [0] 1000000 kbits/sec [1] 1000000 kbits/sec [2] 1000000 kbits/sec [3] 1000000 kbits/sec [4] 1000000 kbits/sec [5] 1000000 kbits/sec [6] 1000000 kbits/sec [7] 1000000 kbits/sec P2P Link: From: 13.13.13.13 To: 11.12.13.14, Local: 11.13.1.13, Remote: 11.13.1.11, LSA Id: 16777220, Gen:919 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 1000000 kbits/sec Reservable BW: 1000000 kbits/sec Unreserved BW: [0] 1000000 kbits/sec [1] 1000000 kbits/sec [2] 1000000 kbits/sec [3] 1000000 kbits/sec [4] 1000000 kbits/sec [5] 1000000 kbits/sec [6] 1000000 kbits/sec [7] 1000000 kbits/sec P2P Link: From: 13.13.13.13 To: 11.12.13.14, Local: 11.13.2.13, Remote: 11.13.2.11, LSA Id: 16777221, Gen:921 Admin Group: 0x0 IGP Metric: 1 TE Metric: 1 Link BW: 1000000 kbits/sec Reservable BW: 1000000 kbits/sec Unreserved BW: [0] 1000000 kbits/sec [1] 1000000 kbits/sec [2] 1000000 kbits/sec [3] 1000000 kbits/sec [4] 1000000 kbits/sec [5] 1000000 kbits/sec [6] 1000000 kbits/sec [7] 1000000 kbits/sec
The show running-config router mpls lsp lsp_name command displays detailed information about a specific LSP name. The output from the show mpls lsp name lsp_name lsp lsp_name command is enhanced to display whether the fate-sharing group information is applied to the path computation for a specified LSP. When the fate-sharing group information is applied, "yes" is displayed in the field. When fate-sharing group information is not applied, "no" is displayed in the field. Fate-sharing group information can also be applied to the path computation for a secondary LSP or a bypass LSP path. In the following example, the fate-sharing group information is applied to LSP test2.
device# show mpls lsp name lsp_name test2 LSP test2, to 10.100.100.100 From: 10.20.20.20, admin: UP, status: UP, tunnel interface(primary path): tnl3 Times primary LSP goes up since enabled: 1 Metric: 0, number of installed aliases: 0 Adaptive Maximum retries: NONE, no. of retries: 0 Pri. path: NONE, up: yes, active: yes Setup priority: 7, hold priority: 0 Max rate: 0 kbps, mean rate: 0 kbps, max burst: 0 bytes Constraint-based routing enabled: yes Tie breaking: random, hop limit: 0 LDP tunneling enabled: no Sec. path: path2, active: no Hot-standby: yes, status: up Setup priority: 7, hold priority: 0 Max rate: 0 kbps, mean rate: 0 kbps, max burst: 0 bytes Constraint-based routing enabled: yes Fate-sharing group applied: yes hop limit: 0 Active Path attributes: Tunnel interface: tnl3, outbound interface: e1/1 Tunnel index: 2, Tunnel instance: 1 outbound label: 3 Path calculated using constraint-based routing: yes Path calculated using interface constraint: no Recorded routes: Protection codes: P: Local N: Node B: Bandwidth I: InUse 10.1.1.1
In the following example output, the primary LSP path, and the secondary bypass LSP path is UP. The add-penalty parameter is enabled under the CSPF group computation mode as highlighted below.
device# show mpls lsp name lsp_name test2 LSP test2, to 10.100.100.100 From: 10.20.20.20, admin: UP, status: UP, tunnel interface(primary path): tnl3 Times primary LSP goes up since enabled: 1 Metric: 0, number of installed aliases: 0 Adaptive Maximum retries: NONE, no. of retries: 0 Pri. path: NONE, up: yes, active: yes ... Sec. path: path2, active: no Hot-standby: yes, status: up Setup priority: 7, hold priority: 0 Max rate: 0 kbps, mean rate: 0 kbps, max burst: 0 bytes Constraint-based routing enabled: yes Path cspf-group computation-mode: add-penalty
